[petsc-dev] Extract sub-matrices efficiently
victor.magri at dicea.unipd.it victor.magri at dicea.unipd.it
Thu May 19 07:21:00 CDT 2016
Il 18-05-2016 21:23 Barry Smith ha scritto:
> Are the many small matrices you are extracting consisting of parts coming from different processes? Or does each sub matrix come from the same process (and remain on the same process) or are most coming from the same process but some shared across multiple processes?
> The parallel code was originally written assuming one wishes to get a small number of large sub matrices. Thus it is a bit communication heavy, for example it doesn't share any communications or all reduce across the matrices. It is, of course, possible to write custom code for your case but in order to help you to do that we need to know more about your particular use case.
> Barry
> On May 18, 2016, at 11:41 AM, Jed Brown <jed at jedbrown.org> wrote:
> Could you give some more information about your preconditioner?
> Sequential extraction of many small submatrices is not high performance,
> but perhaps we can restructure.
> victor.magri at dicea.unipd.it writes:
> Dear PETSc developers,
> I have a matrix of the type MATMPIAIJ from which I want to extract small
> sub-matrices and sub-vectors (number of rows from 1 to 50 maximum)
> several times. This is a very fundamental step of a preconditioner that
> I'm writing. After that, I want to solve these sub-systems locally.
> In my current implementation I use MatGetSubMatrices with
> MAT_INITIAL_MATRIX to extract the sub-matrices and MatGetRow plus some
> other artifacts to extract the sub-vectors. However, I see that this
> procedure is too costly, once it creates and destroys the output
> variables each time they are called. I thought about using the MAT_REUSE
> flag, but I can't since the nonzero pattern of the local sub-matrix may
> change from call to call.
> Can you give me some hint on how to do this task efficiently? I
> appreciate your help!
> Victor A. P. Magri - PhD student
> Dept. of Civil, Environmental and Architectural Eng.
> University of Padova
> Via Marzolo, 9 - 35131 Padova, Italy
Thank you for the prompt reply, Barry and Jed.
If a communication reducing algorithm is firstly used such as the ones
provided by METIS or Scotch, I would say that these sub-matrices are
mostly coming from the same process and just some of them are shared
across multiple processes. The preconditioner that I'm implementing is
the Factorized Sparse Approximate Inverse with adaptive nonzero pattern
generation. You can find it in the journal paper
http://dl.acm.org/citation.cfm?doid=2732672.2629475 [1]. It relies in an
explicit approximation (called matrix F) for the inverse of the lower
triangular Cholesky factor.
Given a maximum number of nonzeros per row of the F matrix, we want to
find the best column positions and their respective values which gives
the largest reduction in the Kaporin condition number of the
preconditioned matrix. This search can be done concurrently from row to
row. Considering an arbitrary row of F, we have to gather a sub-matrix
and a sub-vector with sizes equal to the current number of nonzero
elements already found for F and solve this subsystem, this process is
repeated up to when the desired number of nonzeros is reached. Since the
maximum size of these subsystems is known, I would like to allocate two
local buffer variables (one for the sub-matrix and the other for the
sub-vector) just one time and use it along the whole process, instead of
creating and destroying new variables each time the sub-systems are
gathered. This should reduce a lot the time for building the
preconditioner since it is a task which is done a number of times.
Thank you for your help!
Links:
[1] http://dl.acm.org/citation.cfm?doid=2732672.2629475
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160519/8207d522/attachment.html>
