[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Mark Adams mfadams at lbl.gov
Tue May 17 19:11:42 CDT 2016
OK, I thought you were suggesting that:
unsigned int hash(unsigned int x) {
    x = ((x >> 16) ^ x) * 0x45d9f3b;
    x = ((x >> 16) ^ x);
    return x;}
But, Barry is vetoing this.
On Tue, May 17, 2016 at 4:18 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> > Why not just set each index with hash(i) = (i >> 32)^i and forget
> > VecSetRandom in here?
> Because if your vertices are numbered lexicographically on a Cartesian
> grid, this gives you a plane.  But just put in the legit hash (the one I
> linked is pretty good) and then you don't have to worry about
> accidentally stumbling upon pathological cases.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160517/c94fbb43/attachment.html>
