[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Mark Adams mfadams at lbl.gov
Tue May 17 11:21:41 CDT 2016
On Sat, Aug 22, 2015 at 10:39 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Aug 22, 2015, at 9:26 PM, Mark Adams <mfadams at lbl.gov> wrote:
> >  I would vote for (1).
> > Also, I hope cheb->random is the default.
>    Well then different machines will produce different convergence
> histories which is annoying for any kind of "no change" daily testing.
> Except for you, most of the rest of us don't like the random default, sorry
Well, this bit me and Garth Wells, among others I would guess.
The problem is that RHS are often smooth and this leads to poor convergence
to the highest eigenvalue. As an example on the new ex56, elasticity, cube,
traction on one side, the history of the eigen estimator looks like this
(appended). Garth mentioned that he uses 50 iterations in the eigen
estimator (ie, a lot), and you can see why here, It looks converged at 44
iterations at ~1.42 and then pops up to ~1.72 very quickly.  This is such a
big jump that it overwhelms the common 1.05 safety factor.  If you add
-mg_levels_ksp_chebyshev_esteig_random you see nice smooth and fast
convergence (appended).
Note, the iteration number of this jump seems to be about linear in h, so
this will fail with 50 iterations on a larger problem (this one has about
6M dof).
Now, I guess I can put -mg_levels_ksp_chebyshev_esteig_random in the
tutorials as suggested parameters and keep them out of the tests to avoid
your issue with regression tests.  Right?
ps, I'm sure Jed free climbed out of the pit, so you can use his rope.
       39 KSP Residual norm 5.149666187461e+00 % max 1.423034674475e+00 min
5.820371669083e-04 max/min 2.444920626003e+03
       40 KSP Residual norm 5.157885158697e+00 % max 1.423126042184e+00 min
5.557328840496e-04 max/min 2.560809487850e+03
       41 KSP Residual norm 5.303627521687e+00 % max 1.423199352292e+00 min
5.313351872668e-04 max/min 2.678533977041e+03
       42 KSP Residual norm 5.364384189061e+00 % max 1.423275534927e+00 min
5.062394822273e-04 max/min 2.811466874659e+03
       43 KSP Residual norm 5.490412749639e+00 % max 1.423347554528e+00 min
4.823994222923e-04 max/min 2.950558165607e+03
       44 KSP Residual norm 5.298532106786e+00 % max 1.423435653436e+00 min
4.630735554742e-04 max/min 3.073886721901e+03
       45 KSP Residual norm 5.250150466693e+00 % max 1.444039693619e+00 min
4.458237353578e-04 max/min 3.239037267632e+03
       46 KSP Residual norm 5.355091565702e+00 % max 1.597859894587e+00 min
4.296586330882e-04 max/min 3.718905595128e+03
       47 KSP Residual norm 5.359212994059e+00 % max 1.694500733083e+00 min
4.115503583969e-04 max/min 4.117359391167e+03
       48 KSP Residual norm 5.382627967217e+00 % max 1.715436978188e+00 min
3.945385500813e-04 max/min 4.347957830318e+03
       49 KSP Residual norm 5.333511242816e+00 % max 1.719426018108e+00 min
3.791973408295e-04 max/min 4.534383111304e+03
       50 KSP Residual norm 5.286785239032e+00 % max 1.720488275875e+00 min
3.655323031666e-04 max/min 4.706802274303e+03
with -mg_levels_ksp_chebyshev_esteig_random
        0 KSP Residual norm 4.587476885185e+05 % max 1.000000000000e+00 min
1.000000000000e+00 max/min 1.000000000000e+00
        1 KSP Residual norm 5.000026676130e+05 % max 2.096521908651e-01 min
2.096521908651e-01 max/min 1.000000000000e+00
        2 KSP Residual norm 2.383418066969e+06 % max 9.808897648348e-01 min
5.952257317564e-03 max/min 1.647929033478e+02
        3 KSP Residual norm 2.574503036099e+06 % max 1.019204519789e+00 min
3.039124767415e-03 max/min 3.353611969855e+02
        4 KSP Residual norm 2.458678036734e+06 % max 1.244548092713e+00 min
1.992498130768e-03 max/min 6.246169436720e+02
        5 KSP Residual norm 2.344964690599e+06 % max 1.367637044108e+00 min
1.464901327469e-03 max/min 9.336035256864e+02
        6 KSP Residual norm 2.331695060244e+06 % max 1.404943514389e+00 min
1.190280622651e-03 max/min 1.180346455830e+03
        7 KSP Residual norm 2.271960219657e+06 % max 1.437957455093e+00 min
1.008722431370e-03 max/min 1.425523424853e+03
        8 KSP Residual norm 2.292028741926e+06 % max 1.502852988492e+00 min
8.809546168835e-04 max/min 1.705936900369e+03
        9 KSP Residual norm 2.233478095421e+06 % max 1.582008563628e+00 min
7.783319825046e-04 max/min 2.032562709986e+03
       10 KSP Residual norm 2.217240790630e+06 % max 1.627791394511e+00 min
7.017777386360e-04 max/min 2.319525549035e+03
       11 KSP Residual norm 2.253686552707e+06 % max 1.659357337462e+00 min
6.359067415045e-04 max/min 2.609435046303e+03
       12 KSP Residual norm 2.327352703032e+06 % max 1.682006777543e+00 min
5.780023151159e-04 max/min 2.910034672103e+03
       13 KSP Residual norm 2.258932746968e+06 % max 1.695221701128e+00 min
5.272335154902e-04 max/min 3.215314753940e+03
       14 KSP Residual norm 2.146539128962e+06 % max 1.701712426981e+00 min
4.879541184491e-04 max/min 3.487443517005e+03
       15 KSP Residual norm 2.146242364688e+06 % max 1.705375519134e+00 min
4.576872864507e-04 max/min 3.726071423917e+03
       16 KSP Residual norm 2.160438533108e+06 % max 1.708650293977e+00 min
4.278996767955e-04 max/min 3.993109568984e+03
       17 KSP Residual norm 2.184700124943e+06 % max 1.710853580610e+00 min
4.021751403604e-04 max/min 4.254001326580e+03
       18 KSP Residual norm 2.148601462370e+06 % max 1.712408913049e+00 min
3.793690742988e-04 max/min 4.513833701954e+03
       19 KSP Residual norm 2.195737087965e+06 % max 1.713723267846e+00 min
3.583883046289e-04 max/min 4.781749978199e+03
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160517/8ebfe8f7/attachment.html>
