[petsc-dev] Configure is Broken
Fri May 13 15:23:05 CDT 2016
Who the fuck is holding a fucking file object:
                ERROR in COMMAND LINE ARGUMENT to ./configure
can't pickle file objects
  File "/PETSc3/petsc/petsc-dev/config/BuildSystem/config/framework.py",
line 961, in processChildren
    child.configure()
  File "/PETSc3/petsc/petsc-dev/config/PETSc/Configure.py", line 1096, in
configure
    self.framework.argDB['configureCache'] = cPickle.dumps(self.framework)
  File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/copy_reg.py",
line 70, in _reduce_ex
    raise TypeError, "can't pickle %s objects" % base.__name__
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160513/1ebe46bb/attachment.html>
