[petsc-dev] stability issue
Jose E. Roman jroman at dsic.upv.es
Wed May 4 01:21:50 CDT 2016
> El 4 may 2016, a las 7:35, Vasiliy Kozyrev <ezqc123 at gmail.com> escribió:
> Hi
> I have an issue with solution stability(small variations in
> my matrixes causes significant variations in the solution).
> It looks like a feature of my eigen value problem, because
> for other problems everything works fine.
> Are there any options in the SLEPc which could be helpful
> in such situations?
> Vasily Kozyrev
This question is too generic. What is the problem? Are you getting large residual errors?
Jose
