[petsc-dev] Problems with MatGetSubMatrices_SeqSBAIJ
Hong hzhang at mcs.anl.gov
Tue May 3 10:48:33 CDT 2016
Alejandro :
Fixed
https://bitbucket.org/petsc/petsc/commits/0043d7fe17a5a8a1e4768ab560023392b3862352
It will merged to petsc-release after our nightly tests.
Your detailed report is very helpful, thanks!
Hong
> After updating petsc from version 3.6.2 to 3.7, I had the following
> problem:
> The result that I get from doing something like
> MatMult(schurComplement,v1,v2); differs between the petsc versions that I
> mentioned. I traced back the problem to the function
> MatGetSubMatrices_SeqSBAIJ(). What I did in order to temporarily solve my
> problem was to use in petsc 3.7 the code of MatGetSubMatrices_SeqSBAIJ()
> corresponding to petsc 3.6.2.
> How I solved the problem is not a real solution, but it allows me to keep
> working. My question is: is it a bug or do you think that there could be
> something wrong with my code from which I use petsc?
> I think it should be a bug. If I run the ksp example 59 which uses FETI-DP
> (whose implementation also uses something like
> MatMult(schurComplement,v1,v2)) with petsc 3.7, I get the following
> unexpected answer
> mpiexec -n 4 ./ex59 -npx 2 -npy 2 -nex 60 -ney 60 -ksp_max_it 3
> ------------------FETI-DP stats-------------------------------
> Number of degrees of freedom               :      355
> Number of iterations                       :        3
> Eigenvalues preconditioned operator        : 1.49e+00 8.86e+00
> Error betweeen exact and computed solution : 1.91e+00
> If I run the same problem with petsc 3.7 but with
> MatGetSubMatrices_SeqSBAIJ() corresponding to petsc 3.6.2, I get the
> expected answer
> Eigenvalues preconditioned operator        : 1.08e+00 2.08e+00
> Error betweeen exact and computed solution : 3.60e-02
> Thanks,
> Alejandro
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160503/989e011d/attachment.html>
