[petsc-dev] mpi/cuda issue
Mon Mar 21 22:04:33 CDT 2016
On Mon, 21 Mar 2016, Barry Smith wrote:
> > On Mar 21, 2016, at 9:50 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > BTW: perils of using 'gitcommit=origin/master'
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/03/21/master.html
> > Perhaps we should switch superlu_dist to use a working snapshot?
> >    self.gitcommit        = '35c3b21630d93b3f8392a68e607467c247b5e053'
> > balay at asterix /home/balay/petsc (master=)
> > $ git grep origin/master config
> > config/BuildSystem/config/packages/Chombo.py:    self.gitcommit        = 'origin/master'
> > config/BuildSystem/config/packages/SuperLU_DIST.py:    self.gitcommit        = 'origin/master'
> > config/BuildSystem/config/packages/amanzi.py:    self.gitcommit        = 'origin/master'
> > config/BuildSystem/config/packages/saws.py:    self.gitcommit = 'origin/master'
>   Satish and Hong,
> Sherry has changed SuperLU_dist to have no name conflicts with SuperLU this means we need to update the SuperLU_dist interface for fix these problems. Once things have settled down we can use a release commit instead of master.
Well the current issue is a breakage in superlu_dist build... [not the petsc interface]
Satish
