[petsc-dev] WTF
Andrew McRae A.T.T.McRae at bath.ac.uk
Thu Jun 30 03:24:07 CDT 2016
Justin,
Note that the Firedrake authors did their own Poisson scaling in the
firedrake paper (arXiv <https://arxiv.org/abs/1501.01809>), and they needed
to set custom BoomerAMG options to get good performance.  See pages 6 and
16-18.
If I recall correctly, with the out-of-the-box options, far too many
coarsening stages were done.  This was a 3D Poisson equation, and the weak
scaling results use the space P3, so your results may vary.
Andrew
On 30 June 2016 at 08:40, Justin Chang <jychang48 at gmail.com> wrote:
> That guy's results actually make sense to me.
> I also get poor strong-scaling for the FEM version of the poisson equation
> (via firedrake) using HYPRE's boomerAMG. The studies were done on Intel
> E5-2670 machines and had proper OpenMPI bindings.No HYPRE configure options
> were set via command line so I just used whatever the default setting were.
> If he used ML, GAMG, or even ILU he would likely get much better scaling
> as I have.
> Attached is a speedup plot of a much smaller problem I did (225k dofs),
> but you can still see a similar progression on how HYPRE deteriorates.
> Compared to the other preconditioners, I noticed that HYPRE has a much
> lower flop-to-byte ratio which suggests to me that based on the current
> solver configurations, HYPRE is likely going to be more memory-bandwidth
> and suffer from lack of memory usage as more cores are used.
> Not sure how to properly configure any of these multigrid preconditioners,
> but figured I'd offer my two cents.
> Justin
> On Thu, Jun 30, 2016 at 5:18 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> > On Jun 29, 2016, at 10:06 PM, Jeff Hammond <jeff.science at gmail.com>
>> wrote:
>> > On Wednesday, June 29, 2016, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> >    Who are these people and why to they have this webpage?
>> > Pop up 2-3 directories and you'll see this is a grad student who
>> appears to be trying to learn applied math. Is this really your enemy?
>> Don't you guys have some DOE bigwigs to bash?
>> >     Almost for sure they are doing no process binding and no proper
>> assignment of processes to memory domains.
>> > MVAPICH2 sets affinity by default. Details not given but "infiniband
>> enabled" means it might have been used. I don't know what OpenMPI does by
>> default but affinity alone doesn't explain this.
>>   By affinity you mean that the process just remains on the same core
>> right? You could be right I think the main affect is a bad assignment of
>> processes to cores/memory domains.
>> >  In addition they are likely filling up all the cores on the first node
>> before adding processes to the second core etc.
>> > That's how I would show scaling. Are you suggesting using all the nodes
>> and doing breadth first placement?
>>    I would fill up one process per memory domain moving across the nodes;
>> then go back and start a second process on each memory domain. etc You can
>> also just go across nodes as you suggest and then across memory domains
>>    If you fill up the entire node of cores and then go to the next node
>> you get this affect that the performance goes way down as you fill up the
>> last of the cores (because no more memory bandwidth is available) and then
>> performance goes up again as you jump to the next node and suddenly have a
>> big chunk of additional bandwidth. You also have weird load balancing
>> problem because the first 16 processes are going slow because they share
>> some bandwidth while the 17 runs much faster since it can hog more
>> bandwidth.
>> > Jeff
>> > If the studies had been done properly there should be very little fail
>> off on the strong scaling in going from 1 to 2 to 4 processes and even
>> beyond. Similarly the huge fail off in going from 4 to 8 to 16 would not
>> occur for weak scaling.
>> >    Barry
>> > > On Jun 29, 2016, at 7:47 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > >   http://guest.ams.sunysb.edu/~zgao/work/airfoil/scaling.html
>> > > Can we rerun this on something at ANL since I think this cannot be
>> true.
>> > >    Matt
>> > > What most experimenters take for granted before they begin their
>> experiments lead.
>> > > -- Norbert Wiener
>> > Jeff Hammond
>> > http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160630/b605183b/attachment.html>
