[petsc-dev] asm / gasm
Mark Adams mfadams at lbl.gov
Fri Jun 24 11:36:35 CDT 2016
I think I found the/a problem. It is failing on the current test when it
adds equation 144 to GASM. This test has a 3^3 cell mesh so a 4^3 vertex
mesh.  There one face with BCs, that means there is a 4x4x3 mesh.  With
bs==3, there are 144 equations, equation number 144 is the first
out-of-bounds equation.  This seems like a suspicious coincidence.
It has been a long time since I've looked that code but I also see that
this test has two aggregates and the IS's that I give GASM have 54 and 90
equations in them. So it looks like I am taking out the BCs.
[I just got your new message ...]
On Fri, Jun 24, 2016 at 4:52 PM, Mark Adams <mfadams at lbl.gov> wrote:
> OK, but how should I proceed?
> On Fri, Jun 24, 2016 at 4:47 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> > On Jun 24, 2016, at 9:35 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> > Barry,
>> > ASM worked before GASM existed. I've never heard of GASM until
>> yesterday, other than seeing the directory in the source.
>>    Pretty impressive you never heard of GASM and yet YOU put the GASM
>> code into GAMG
>> a2f3521de src/ksp/pc/impls/gamg/gamg.c      (Mark Adams
>>  2012-05-01 12:48:43 -0400  604)
>>  2012-05-01 12:48:43 -0400  605)       /* set defaults */
>> 806fa848a src/ksp/pc/impls/gamg/gamg.c      (Barry Smith
>> 2013-01-02 02:05:45 -0600  606)       ierr = KSPSetType(smoother,
>> KSPCHEBYSHEV);CHKERRQ(ierr);
>> ffc955d6d src/ksp/pc/impls/gamg/gamg.c      (Mark Adams
>>  2012-03-27 19:09:54 -0400  607)
>> 1b18a24a4 src/ksp/pc/impls/gamg/gamg.c      (Mark Adams
>>  2013-11-02 15:56:24 -0400  608)       /* set blocks for GASM smoother that
>> uses the 'aggregates' */
>> 2013-01-02 02:05:45 -0600  609)       if (pc_gamg->use_aggs_in_gasm) {
>> 2d3561bba src/ksp/pc/impls/gamg/gamg.c      (Satish Balay
>>  2012-03-29 12:58:42 -0500  610)         PetscInt sz;
>> 2fa5cd679 src/ksp/pc/impls/gamg/gamg.c      (Karl Rupp
>> 2013-01-30 22:53:06 -0600  611)         IS       *is;
>>  2012-05-01 12:48:43 -0400  612)
>> 2013-01-30 22:53:06 -0600  613)         sz   = nASMBlocksArr[level];
>> 2013-01-30 22:53:06 -0600  614)         is   = ASMLocalIDsArr[level];
>> 2013-01-02 02:05:45 -0600  615)         ierr = PCSetType(subpc,
>> PCGASM);CHKERRQ(ierr);
>>  2013-11-02 15:56:24 -0400  616)         ierr = PCGASMSetOverlap(subpc,
>> 0);CHKERRQ(ierr);
>> 7f66b68fb src/ksp/pc/impls/gamg/gamg.c      (Mark Adams
>>  2015-08-11 09:52:40 -0400  617)         if (!sz) {
>> 2013-01-30 22:53:06 -0600  618)           IS       is;
>>  2012-03-27 19:09:54 -0400  619)           PetscInt my0,kk;
>> 2013-01-02 02:05:45 -0600  620)           ierr =
>> MatGetOwnershipRange(Aarr[level], &my0
>>    I think you put in the GASM but then forgot and thought you put in ASM.
>> >  It has been so long, I could probably hunt for a working version, but
>> who cares, we are going to roll back 5 years?
>> > > In branch mark/gamg-agg-asm in ksp ex56, 'make runex56':
>> >    I don't care about this! This is where you have tried to change from
>> GASM to ASM which I told you is non-trivial.
>> > Give me the example and command line where the GASM version in master
>> (or maint) doesn't work where the error message includes ** Max-trans not
>> allowed because matrix is distributed
>> > Why do you want to debug GASM?  I thought we wanted to use ASM.  It is
>> not clear why converting from GASM to ASM is non-trivial, I could have done
>> this from the command line. This use aggregate-asm stuff just does what a
>> clever user might do.
>> >    We are not communicating very well, you jumped from stating GASM
>> crashed to monkeying with ASM and now refuse to tell me how to reproduce
>> the GASM crash.
>> > I don't think you want to mess with GASM, BUT if you run ksp/ex56 with:
>> > -pc_gamg_use_agg_gasm -mg_levels_pc_type gasm
>> > and remove the existing -mg_levels_pc_type sor, you should see an error
>> that Garth and I saw (eg, appended).
>> > We have to start by fixing the current code to work with GASM (if it
>> ever worked) and then move on to using ASM (which is just an optimization
>> of the GASM usage.)
>> > Are you sure? I am deep into debugging asm with DDT.  I can switch to
>> GASM by just calling the GASM set block method and use gasm in the PC, and
>> continue with DDT debugging.
>> > Let me know.
>> > 16:29 master *= ~/Codes/petsc/src/ksp/ksp/examples/tutorials$ make
>> runex56
>> > 1,4c1,85
>> > < Linear solve converged due to CONVERGED_RTOL iterations 8
>> > < [0]main |b-Ax|/|b|=1.940043e-04, |b|=4.969822e+00, emax=9.926090e-01
>> > > [1]PETSC ERROR:
>> > > [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> > > [1]PETSC ERROR: Try option -start_in_debugger or
>> -on_error_attach_debugger
>> > > [1]PETSC ERROR: or see
>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> > > [1]PETSC ERROR: [2]PETSC ERROR:
>> > > [2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> > > [2]PETSC ERROR: Try option -start_in_debugger or
>> > > [2]PETSC ERROR: or see
>> > > [2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>> Mac OS X to find memory corruption errors
>> > > [6]PETSC ERROR:
>> > > [6]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> > > [6]PETSC ERROR: Try option -start_in_debugger or
>> > > [6]PETSC ERROR: or see
>> > > [6]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>> > > [4]PETSC ERROR:
>> > > [4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> > > [4]PETSC ERROR: Try option -start_in_debugger or
>> > > [4]PETSC ERROR: or see
>> > > [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>> > > [6]PETSC ERROR: likely location of problem given in stack below
>> > > [6]PETSC ERROR: ---------------------  Stack Frames
>> > > [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>> available,
>> > > [6]PETSC ERROR:       INSTEAD the line number of the start of the
>> function
>> > > [6]PETSC ERROR:       is given.
>> > > [6]PETSC ERROR: [6] MatGetSubMatrices_MPIAIJ_Local line 1228
>> /Users/markadams/Codes/petsc/src/mat/impls/aij/mpi/mpiov.c
>> > > [6]PETSC ERROR: [6] MatGetSubMatrices_MPIAIJ line 1131
>> > > [6]PETSC ERROR: [6] MatGetSubMatricesMPI_MPIXAIJ line 2163
>> > > [6]PETSC ERROR: [6] MatGetSubMatricesMPI_MPIAIJ line 2418
>> > > [6]PETSC ERROR: [6] MatGetSubMatricesMPI line 6805
>> /Users/markadams/Codes/petsc/src/mat/interface/matrix.c
>> > > [6]PETSC ERROR: [6] PCSetUp_GASM line 357
>> /Users/markadams/Codes/petsc/src/ksp/pc/impls/gasm/gasm.c
>> > > [6]PETSC ERROR: [6] PCSetUp line 930
>> /Users/markadams/Codes/petsc/src/ksp/pc/interface/precon.c
>> > > [6]PETSC ERROR: [6] KSPSetUp line 305
>> /Users/markadams/Codes/petsc/src/ksp/ksp/interface/itfunc.c
>> > > [6]PETSC ERROR: [6] PCSetUp_MG line 561
>> /Users/markadams/Codes/petsc/src/ksp/pc/impls/mg/mg.c
>> > > [6]PETSC ERROR: --------------------- Error Message
>> > > [6]PETSC ERROR: Signal received
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160624/7f0356ec/attachment.html>
