[petsc-dev] asm / gasm
Mark Adams mfadams at lbl.gov
Fri Jun 24 09:52:11 CDT 2016
OK, but how should I proceed?
On Fri, Jun 24, 2016 at 4:47 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jun 24, 2016, at 9:35 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > Barry,
> > ASM worked before GASM existed. I've never heard of GASM until
> yesterday, other than seeing the directory in the source.
>    Pretty impressive you never heard of GASM and yet YOU put the GASM code
> into GAMG
> a2f3521de src/ksp/pc/impls/gamg/gamg.c      (Mark Adams
>  2012-05-01 12:48:43 -0400  604)
>  2012-05-01 12:48:43 -0400  605)       /* set defaults */
> 806fa848a src/ksp/pc/impls/gamg/gamg.c      (Barry Smith
> 2013-01-02 02:05:45 -0600  606)       ierr = KSPSetType(smoother,
> KSPCHEBYSHEV);CHKERRQ(ierr);
> ffc955d6d src/ksp/pc/impls/gamg/gamg.c      (Mark Adams
>  2012-03-27 19:09:54 -0400  607)
> 1b18a24a4 src/ksp/pc/impls/gamg/gamg.c      (Mark Adams
>  2013-11-02 15:56:24 -0400  608)       /* set blocks for GASM smoother that
> uses the 'aggregates' */
> 2013-01-02 02:05:45 -0600  609)       if (pc_gamg->use_aggs_in_gasm) {
> 2d3561bba src/ksp/pc/impls/gamg/gamg.c      (Satish Balay
>  2012-03-29 12:58:42 -0500  610)         PetscInt sz;
> 2fa5cd679 src/ksp/pc/impls/gamg/gamg.c      (Karl Rupp
> 2013-01-30 22:53:06 -0600  611)         IS       *is;
>  2012-05-01 12:48:43 -0400  612)
> 2013-01-30 22:53:06 -0600  613)         sz   = nASMBlocksArr[level];
> 2013-01-30 22:53:06 -0600  614)         is   = ASMLocalIDsArr[level];
> 2013-01-02 02:05:45 -0600  615)         ierr = PCSetType(subpc,
> PCGASM);CHKERRQ(ierr);
>  2013-11-02 15:56:24 -0400  616)         ierr = PCGASMSetOverlap(subpc,
> 0);CHKERRQ(ierr);
> 7f66b68fb src/ksp/pc/impls/gamg/gamg.c      (Mark Adams
>  2015-08-11 09:52:40 -0400  617)         if (!sz) {
> 2013-01-30 22:53:06 -0600  618)           IS       is;
>  2012-03-27 19:09:54 -0400  619)           PetscInt my0,kk;
> 2013-01-02 02:05:45 -0600  620)           ierr =
> MatGetOwnershipRange(Aarr[level], &my0
>    I think you put in the GASM but then forgot and thought you put in ASM.
> >  It has been so long, I could probably hunt for a working version, but
> who cares, we are going to roll back 5 years?
> > > In branch mark/gamg-agg-asm in ksp ex56, 'make runex56':
> >    I don't care about this! This is where you have tried to change from
> GASM to ASM which I told you is non-trivial.
> > Give me the example and command line where the GASM version in master
> (or maint) doesn't work where the error message includes ** Max-trans not
> allowed because matrix is distributed
> > Why do you want to debug GASM?  I thought we wanted to use ASM.  It is
> not clear why converting from GASM to ASM is non-trivial, I could have done
> this from the command line. This use aggregate-asm stuff just does what a
> clever user might do.
> >    We are not communicating very well, you jumped from stating GASM
> crashed to monkeying with ASM and now refuse to tell me how to reproduce
> the GASM crash.
> > I don't think you want to mess with GASM, BUT if you run ksp/ex56 with:
> > -pc_gamg_use_agg_gasm -mg_levels_pc_type gasm
> > and remove the existing -mg_levels_pc_type sor, you should see an error
> that Garth and I saw (eg, appended).
> > We have to start by fixing the current code to work with GASM (if it
> ever worked) and then move on to using ASM (which is just an optimization
> of the GASM usage.)
> > Are you sure? I am deep into debugging asm with DDT.  I can switch to
> GASM by just calling the GASM set block method and use gasm in the PC, and
> continue with DDT debugging.
> > Let me know.
> > 16:29 master *= ~/Codes/petsc/src/ksp/ksp/examples/tutorials$ make
> runex56
> > 1,4c1,85
> > < Linear solve converged due to CONVERGED_RTOL iterations 8
> > < [0]main |b-Ax|/|b|=1.940043e-04, |b|=4.969822e+00, emax=9.926090e-01
> > > [1]PETSC ERROR:
> > > [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> > > [1]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > > [1]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > > [1]PETSC ERROR: [2]PETSC ERROR:
> > > [2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > > [2]PETSC ERROR: Try option -start_in_debugger or
> > > [2]PETSC ERROR: or see
> > > [2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS X to find memory corruption errors
> > > [6]PETSC ERROR:
> > > [6]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > > [6]PETSC ERROR: Try option -start_in_debugger or
> > > [6]PETSC ERROR: or see
> > > [6]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> > > [4]PETSC ERROR:
> > > [4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > > [4]PETSC ERROR: Try option -start_in_debugger or
> > > [4]PETSC ERROR: or see
> > > [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> > > [6]PETSC ERROR: likely location of problem given in stack below
> > > [6]PETSC ERROR: ---------------------  Stack Frames
> > > [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > > [6]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> > > [6]PETSC ERROR:       is given.
> > > [6]PETSC ERROR: [6] MatGetSubMatrices_MPIAIJ_Local line 1228
> /Users/markadams/Codes/petsc/src/mat/impls/aij/mpi/mpiov.c
> > > [6]PETSC ERROR: [6] MatGetSubMatrices_MPIAIJ line 1131
> > > [6]PETSC ERROR: [6] MatGetSubMatricesMPI_MPIXAIJ line 2163
> > > [6]PETSC ERROR: [6] MatGetSubMatricesMPI_MPIAIJ line 2418
> > > [6]PETSC ERROR: [6] MatGetSubMatricesMPI line 6805
> /Users/markadams/Codes/petsc/src/mat/interface/matrix.c
> > > [6]PETSC ERROR: [6] PCSetUp_GASM line 357
> /Users/markadams/Codes/petsc/src/ksp/pc/impls/gasm/gasm.c
> > > [6]PETSC ERROR: [6] PCSetUp line 930
> /Users/markadams/Codes/petsc/src/ksp/pc/interface/precon.c
> > > [6]PETSC ERROR: [6] KSPSetUp line 305
> /Users/markadams/Codes/petsc/src/ksp/ksp/interface/itfunc.c
> > > [6]PETSC ERROR: [6] PCSetUp_MG line 561
> /Users/markadams/Codes/petsc/src/ksp/pc/impls/mg/mg.c
> > > [6]PETSC ERROR: --------------------- Error Message
> > > [6]PETSC ERROR: Signal received
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160624/ca2930a1/attachment.html>
