[petsc-dev] MatMFFDSetType
Adrian Croucher a.croucher at auckland.ac.nz
Fri Jun 24 00:13:22 CDT 2016
Further to this, I debugged into PetscObjectTypeCompare().
It's returning PETSC_FALSE because the type name of the variable mat is
"seqbaij" (and I guess would normally be something like "mpibaij" if
running in parallel outside gdb), which doesn't match with MATMFFD (=
"mffd").
Does that mean I should be setting the matrix type to MATMFFD to get
this to work?
- Adrian
On 24/06/16 16:35, Adrian Croucher wrote:
> On 24/06/16 15:58, Adrian Croucher wrote:
>> I will try debugging into MatMFFDSetType() and seeing what it's doing
>> when I pass in "ds".
> I did this. In MatMFFDSetType() (mffd.c: 116), it executes
>   ierr =
> PetscObjectTypeCompare((PetscObject)mat,MATMFFD,&match);CHKERRQ(ierr);
> which returns match = PETSC_FALSE. The next line
>   if (!match) PetscFunctionReturn(0);
> means it just returns out of there without doing anything.
> - Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 84611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160624/e882d555/attachment.html>
