[petsc-dev] asm / gasm
Mark Adams mfadams at lbl.gov
Thu Jun 23 16:19:46 CDT 2016
The question boils down to, for empty processors do we:
ierr = ISCreateGeneral(PETSC_COMM_SELF, 0, NULL, PETSC_COPY_VALUES,
&is);CHKERRQ(ierr);
          ierr = PCASMSetLocalSubdomains(subpc, 1, &is, NULL);CHKERRQ(ierr);
          ierr = ISDestroy(&is);CHKERRQ(ierr);
or
PCASMSetLocalSubdomains(subpc, 0, NULL, NULL);
The later gives and error that one domain is need and the later gives an
error (appended).
I've checked in the code for this second error in ksp (make runex56)
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: MPI_Allreduce() called in different locations (code lines)
on different processors
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.2-633-g4f88208  GIT
Date: 2016-06-23 18:53:31 +0200
[0]PETSC ERROR:
/global/u2/m/madams/petsc/src/ksp/ksp/examples/tutorials/./ex56 on a
arch-xc30-dbg64-intel named nid00495 by madams Thu Jun 23 14:12:57 2016
[0]PETSC ERROR: Configure options --COPTFLAGS="-no-ipo -g -O0"
--CXXOPTFLAGS="-no-ipo -g -O0" --FOPTFLAGS="-fast -no-ipo -g -O0"
--download-parmetis --download-metis --with-ssl=0 --with-cc=cc
--with-clib-autodetect=0 --with-cxx=CC --with-cxxlib-autodetect=0
--with-debugging=1 --with-fc=0 --with-shared-libraries=0 --with-x=0
--with-mpiexec=srun LIBS=-lstdc++ --with-64-bit-indices
PETSC_ARCH=arch-xc30-dbg64-intel
[0]PETSC ERROR: #1 MatGetSubMatrices_MPIAIJ() line 1147 in
/global/u2/m/madams/petsc/src/mat/impls/aij/mpi/mpiov.c
[0]PETSC ERROR: #2 MatGetSubMatrices_MPIAIJ() line 1147 in
[1]PETSC ERROR: --------------------- Error Message
On Thu, Jun 23, 2016 at 8:05 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Where is the command line that generates the error?
> > On Jun 23, 2016, at 12:08 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > [adding Garth]
> > On Thu, Jun 23, 2016 at 12:52 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> >   Mark,
> >    I think there is a misunderstanding here. With GASM an individual
> block problem is __solved__ (via a parallel KSP) in parallel by several
> processes, with ASM each block is "owned" by and solved on a single process.
> > Ah, OK, so this is for multiple processors in a block. Yes, we are
> looking at small, smother, blocks.
> >    With both the "block" can come from any unknowns on any processes.
> You can have, for example a block that comes from a region snaking across
> several processes if you like (or it makes sense due to coupling in the
> matrix).
> >    By default if you use ASM it will create one non-overlapping block
> defined by all unknowns owned by a single process and then extend it by
> "one level" (defined by the nonzero structure of the matrix) to get
> overlapping.
> > The default in ASM is one level of overlap? That is new.  (OK, I have
> not looked at ASM in like over 10 years)
> > If you use multiple blocks per process it defines the non-overlapping
> blocks within a single process's unknowns
> > I assume this still chops the matrix and does not call a partitioner.
> > and extends each of them to have overlap (again by the non-zero
> structure of the matrix). The default is simple because the user only need
> indicate the number of blocks per process, the drawback is of course that
> it does depend on the process layout, number of processes etc and does not
> take into account particular "coupling information" that the user may know
> about with their problem.
> >   If the user wishes to defined the blocks themselves that is also
> possible with PCASMSetSubLocalSubdomains(). Each process provides 1 or more
> index sets for the subdomains it will solve on. Note that the index sets
> can contain any unknowns in the entire problem so the blocks do not have to
> "line up" with the parallel decomposition at all.
> > Oh, OK, this is what I want. (I thought this worked).
> > Of course determining and providing good such subdomains may not always
> be clear.
> > In smoothed aggregation there is an argument that the aggregates are
> good, but the scale is fixed obviously.  On a regular grid smoothed
> aggregation wants 3^D sized aggregates, which is obviously wonderful for
> AMS.  And for anisotropy you want your ASM blocks to be on strongly
> connected components, which is what smoothed aggregation wants (not that I
> do this very well).
> >   I see in GAMG you have PCGAMGSetUseASMAggs
> > But the code calls PCGASMSetSubdomains and the command line is
> -pc_gamg_use_agg_gasm, so this is all messed up.  (more below)
> > which sadly does not have an explanation in the users manual and sadly
> does not have a matching options data base name -pc_gamg_use_agg_gasm
> following the rule of drop the word set, all lower case, and put _ between
> words the option should be -pc_gamg_use_asm_aggs.
> > BUT, THIS IS THE WAY IT WAS!  It looks like someone hijacked this code
> and made it gasm.  I never did this.
> > Barry: you did this apparently in 2013.
> >    In addition to this one you could also have one that uses the aggs
> but use the PCASM to manage the solves instead of GASM, it would likely be
> less buggy and more efficient.
> > yes
> >   Please tell me exactly what example you tried to run with what options
> and I will debug it.
> > We got an error message:
> > ** Max-trans not allowed because matrix is distributed
> > Garth: is this from your code perhaps? I don't see it in PETSc.
> > Note that ALL functionality that is included in PETSc should have tests
> that test that functionality then we will find out immediately when it is
> broken instead of two years later when it is much harder to debug. If this
> -pc_gamg_use_agg_gasm had had a test we won't be in this mess now. (Jed's
> damn code reviews sure don't pick up this stuff).
> > First we need to change gasm to asm.
> > We could add this argument pc_gamg_use_agg_asm  to ksp/ex56 (runex56 or
> make a new test).  The SNES version (also ex56) is my current test that I
> like to refer to as recommended parameters for elasticity. So I'd like to
> keep that clean, but we can add junk to ksp/ex56.
> > I've done this in a branch mark/gamg-agg-asm.  I get an error
> (appended). It looks like the second coarsest grid, which has 36 dof on one
> processor has an index 36 in the block on every processor. Strange.  I can
> take a look at it later.
> > Mark
> > > [3]PETSC ERROR: [4]PETSC ERROR: --------------------- Error Message
> > > [4]PETSC ERROR: Petsc has generated inconsistent data
> > > [4]PETSC ERROR: ith 0 block entry 36 not owned by any process, upper
> bound 36
> > > [4]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > > [4]PETSC ERROR: Petsc Development GIT revision: v3.7.2-630-g96e0c40
> GIT Date: 2016-06-22 10:03:02 -0500
> > > [4]PETSC ERROR: ./ex56 on a arch-macosx-gnu-g named MarksMac-3.local
> by markadams Thu Jun 23 06:53:27 2016
> > > [4]PETSC ERROR: Configure options COPTFLAGS="-g -O0" CXXOPTFLAGS="-g
> -O0" FOPTFLAGS="-g -O0" --download-hypre=1 --download-parmetis=1
> --download-metis=1 --download-ml=1 --download-p4est=1 --download-exodus=1
> --download-triangle=1 --with-hdf5-dir=/Users/markadams/Codes/hdf5
> --with-x=0 --with-debugging=1 PETSC_ARCH=arch-macosx-gnu-g --download-chaco
> > > [4]PETSC ERROR: #1 VecScatterCreate_PtoS() line 2348 in
> /Users/markadams/Codes/petsc/src/vec/vec/utils/vpscat.c
> > > [4]PETSC ERROR: #2 VecScatterCreate() line 1552 in
> /Users/markadams/Codes/petsc/src/vec/vec/utils/vscat.c
> > > [3]PETSC ERROR: ith 0 block entry 36 not owned by any process, upper
> bound 36
> > > [3]PETSC ERROR: See
> > > [3]PETSC ERROR: Petsc Development GIT revision: v3.7.2-630-g96e0c40
> > > [3]PETSC ERROR: ./ex56 on a arch-macosx-gnu-g named MarksMac-3.local
> > > [3]PETSC ERROR: Configure options COPTFLAGS="-g -O0" CXXOPTFLAGS="-g
> > > [3]PETSC ERROR: #1 VecScatterCreate_PtoS() line 2348 in
> > > [3]PETSC ERROR: #2 VecScatterCreate() line 1552 in
> > > [3]PETSC ERROR: #3 PCSetUp_ASM() line 279 in
> /Users/markadams/Codes/petsc/src/ksp/pc/impls/asm/asm.c
> >    Barry
> > > On Jun 22, 2016, at 5:20 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > On Wed, Jun 22, 2016 at 8:06 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > >    I suggest focusing on asm.
> > > OK, I will switch gasm to asm, this does not work anyway.
> > > Having blocks that span multiple processes seems like over kill for a
> smoother ?
> > > No, because it is a pain to have the math convolved with the parallel
> decompositions strategy (ie, I can't tell an application how to partition
> their problem). If an aggregate spans processor boundaries, which is fine
> and needed, and let's say we have a pretty uniform problem, then if the
> block gets split up, H is small in part of the domain and convergence could
> suffer along processor boundaries.  And having the math change as the
> parallel decomposition changes is annoying.
> > > (Major league overkill) in fact doesn't one want multiple blocks per
> process, ie. pretty small blocks.
> > > No, it is just doing what would be done in serial.  If the cost of
> moving the data across the processor is a problem then that is a tradeoff
> to consider.
> > > And I think you are misunderstanding me.  There are lots of blocks per
> process (the aggregates are say 3^D in size).  And many of the
> aggregates/blocks along the processor boundary will be split between
> processors, resulting is mall blocks and weak ASM PC on processor
> boundaries.
> > > I can understand ASM not being general and not letting blocks span
> processor boundaries, but I don't think the extra matrix communication
> costs are a big deal (done just once) and the vector communication costs
> are not bad, it probably does not include (too many) new processors to
> communicate with.
> > >    Barry
> > > > On Jun 22, 2016, at 7:51 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > > > I'm trying to get block smoothers to work for gamg.  We (Garth)
> tried this and got this error:
> > > >  - Another option is use '-pc_gamg_use_agg_gasm true' and use
> '-mg_levels_pc_type gasm'.
> > > > Running in parallel, I get
> > > > First, what is the difference between asm and gasm?
> > > > Second, I need to fix this to get block smoothers. This used to
> work.  Did we lose the capability to have blocks that span processor
> subdomains?
> > > > gamg only aggregates across processor subdomains within one layer,
> so maybe I could use one layer of overlap in some way?
> > > > Thanks,
> > > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160623/166bf51e/attachment.html>
