[petsc-dev] DMGetOutputDM hangs on multiple procs
Thu Jun 23 08:33:45 CDT 2016
On Thu, Jun 23, 2016 at 5:46 AM, Sander Arens <Sander.Arens at ugent.be> wrote:
> I noticed that DMGetOutputDM hangs when using multiple procs. The culprit
> is
> https://bitbucket.org/petsc/petsc/commits/c26acbdef0eedda92db6423afb8b38a1502ca0c8.
> This doesn't work when one or more procs don't have any constraints while
> others have, because the ones with constraints call DMClone (collective)
> while the other procs don't.
Yep, will have to make the constraint logic global. I can do this at the
PETSc Meeting
next week in Vienna.
    Matt
> Thanks,
> Sander
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160623/8cca894e/attachment.html>
