[petsc-dev] asm / gasm
Mark Adams mfadams at lbl.gov
Thu Jun 23 07:16:16 CDT 2016
I'm not sure how to create an empty subdomain in ASM.  I get this error in
KSPSetup.  I think this is empty subdomains.  The old code, that worked
once, was giving me the errors that I sent before.  Now I do this:
if (!sz) {
          IS       is;
          ierr = ISCreateGeneral(PETSC_COMM_SELF, 0, NULL,
PETSC_COPY_VALUES, &is);CHKERRQ(ierr);
          ierr = PCASMSetLocalSubdomains(subpc, 1, &is, NULL);CHKERRQ(ierr);
          ierr = ISDestroy(&is);CHKERRQ(ierr);
        } else {
I will keep digging.
14:09 mark/gamg-agg-asm *= ~/Codes/petsc/src/ksp/ksp/examples/tutorials$
make PETSC_ARCH=arch-macosx-gnu-O runex56
[2]PETSC ERROR: #1 VecScatterCreate() line 1492 in
/Users/markadams/Codes/petsc/src/vec/vec/utils/vscat.c
[2]PETSC ERROR: #2 PCSetUp_ASM() line 279 in
/Users/markadams/Codes/petsc/src/ksp/pc/impls/asm/asm.c
[2]PETSC ERROR: #3 PCSetUp() line 968 in
/Users/markadams/Codes/petsc/src/ksp/pc/interface/precon.c
[2]PETSC ERROR: #4 KSPSetUp() line 390 in
/Users/markadams/Codes/petsc/src/ksp/ksp/interface/itfunc.c
[2]PETSC ERROR: #5 PCSetUp_MG() line 783 in
/Users/markadams/Codes/petsc/src/ksp/pc/impls/mg/mg.c
[2]PETSC ERROR: #6 PCSetUp_GAMG() line 675 in
/Users/markadams/Codes/petsc/src/ksp/pc/impls/gamg/gamg.c
[2]PETSC ERROR: #7 PCSetUp() line 968 in
[2]PETSC ERROR: #8 KSPSetUp() line 390 in
[2]PETSC ERROR: #9 main() line 279 in
/Users/markadams/Codes/petsc/src/ksp/ksp/examples/tutorials/ex56.c
On Thu, Jun 23, 2016 at 7:08 AM, Mark Adams <mfadams at lbl.gov> wrote:
> [adding Garth]
> On Thu, Jun 23, 2016 at 12:52 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Mark,
>>    I think there is a misunderstanding here. With GASM an individual
>> block problem is __solved__ (via a parallel KSP) in parallel by several
>> processes, with ASM each block is "owned" by and solved on a single process.
> Ah, OK, so this is for multiple processors in a block. Yes, we are looking
> at small, smother, blocks.
>>    With both the "block" can come from any unknowns on any processes. You
>> can have, for example a block that comes from a region snaking across
>> several processes if you like (or it makes sense due to coupling in the
>> matrix).
>>    By default if you use ASM it will create one non-overlapping block
>> defined by all unknowns owned by a single process and then extend it by
>> "one level" (defined by the nonzero structure of the matrix) to get
>> overlapping.
> The default in ASM is one level of overlap? That is new.  (OK, I have not
> looked at ASM in like over 10 years)
>> If you use multiple blocks per process it defines the non-overlapping
>> blocks within a single process's unknowns
> I assume this still chops the matrix and does not call a partitioner.
>> and extends each of them to have overlap (again by the non-zero structure
>> of the matrix). The default is simple because the user only need indicate
>> the number of blocks per process, the drawback is of course that it does
>> depend on the process layout, number of processes etc and does not take
>> into account particular "coupling information" that the user may know about
>> with their problem.
>>   If the user wishes to defined the blocks themselves that is also
>> possible with PCASMSetSubLocalSubdomains(). Each process provides 1 or more
>> index sets for the subdomains it will solve on. Note that the index sets
>> can contain any unknowns in the entire problem so the blocks do not have to
>> "line up" with the parallel decomposition at all.
> Oh, OK, this is what I want. (I thought this worked).
>> Of course determining and providing good such subdomains may not always
>> be clear.
> In smoothed aggregation there is an argument that the aggregates are good,
> but the scale is fixed obviously.  On a regular grid smoothed aggregation
> wants 3^D sized aggregates, which is obviously wonderful for AMS.  And for
> anisotropy you want your ASM blocks to be on strongly connected components,
> which is what smoothed aggregation wants (not that I do this very well).
>>   I see in GAMG you have PCGAMGSetUseASMAggs
> But the code calls PCGASMSetSubdomains and the command line
> is -pc_gamg_use_agg_gasm, so this is all messed up.  (more below)
>> which sadly does not have an explanation in the users manual and sadly
>> does not have a matching options data base name -pc_gamg_use_agg_gasm
>> following the rule of drop the word set, all lower case, and put _ between
>> words the option should be -pc_gamg_use_asm_aggs.
> BUT, THIS IS THE WAY IT WAS!  It looks like someone hijacked this code and
> made it gasm.  I never did this.
> Barry: you did this apparently in 2013.
>>    In addition to this one you could also have one that uses the aggs but
>> use the PCASM to manage the solves instead of GASM, it would likely be less
>> buggy and more efficient.
> yes
>>   Please tell me exactly what example you tried to run with what options
>> and I will debug it.
> We got an error message:
> ** Max-trans not allowed because matrix is distributed
> Garth: is this from your code perhaps? I don't see it in PETSc.
>> Note that ALL functionality that is included in PETSc should have tests
>> that test that functionality then we will find out immediately when it is
>> broken instead of two years later when it is much harder to debug. If this
>> -pc_gamg_use_agg_gasm had had a test we won't be in this mess now. (Jed's
>> damn code reviews sure don't pick up this stuff).
> First we need to change gasm to asm.
> We could add this argument pc_gamg_use_agg_asm  to ksp/ex56 (runex56 or
> make a new test).  The SNES version (also ex56) is my current test that I
> like to refer to as recommended parameters for elasticity. So I'd like to
> keep that clean, but we can add junk to ksp/ex56.
> I've done this in a branch mark/gamg-agg-asm.  I get an error (appended).
> It looks like the second coarsest grid, which has 36 dof on one processor
> has an index 36 in the block on every processor. Strange.  I can take a
> look at it later.
> Mark
> > [3]PETSC ERROR: [4]PETSC ERROR: --------------------- Error Message
> > [4]PETSC ERROR: Petsc has generated inconsistent data
> > [4]PETSC ERROR: ith 0 block entry 36 not owned by any process, upper
> bound 36
> > [4]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [4]PETSC ERROR: Petsc Development GIT revision: v3.7.2-630-g96e0c40  GIT
> Date: 2016-06-22 10:03:02 -0500
> > [4]PETSC ERROR: ./ex56 on a arch-macosx-gnu-g named MarksMac-3.local by
> markadams Thu Jun 23 06:53:27 2016
> > [4]PETSC ERROR: Configure options COPTFLAGS="-g -O0" CXXOPTFLAGS="-g
> -O0" FOPTFLAGS="-g -O0" --download-hypre=1 --download-parmetis=1
> --download-metis=1 --download-ml=1 --download-p4est=1 --download-exodus=1
> --download-triangle=1 --with-hdf5-dir=/Users/markadams/Codes/hdf5
> --with-x=0 --with-debugging=1 PETSC_ARCH=arch-macosx-gnu-g --download-chaco
> > [4]PETSC ERROR: #1 VecScatterCreate_PtoS() line 2348 in
> /Users/markadams/Codes/petsc/src/vec/vec/utils/vpscat.c
> > [4]PETSC ERROR: #2 VecScatterCreate() line 1552 in
> > [3]PETSC ERROR: ith 0 block entry 36 not owned by any process, upper
> bound 36
> > [3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > [3]PETSC ERROR: Petsc Development GIT revision: v3.7.2-630-g96e0c40  GIT
> > [3]PETSC ERROR: ./ex56 on a arch-macosx-gnu-g named MarksMac-3.local by
> > [3]PETSC ERROR: Configure options COPTFLAGS="-g -O0" CXXOPTFLAGS="-g
> > [3]PETSC ERROR: #1 VecScatterCreate_PtoS() line 2348 in
> > [3]PETSC ERROR: #2 VecScatterCreate() line 1552 in
> > [3]PETSC ERROR: #3 PCSetUp_ASM() line 279 in
>>    Barry
>> > On Jun 22, 2016, at 5:20 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > On Wed, Jun 22, 2016 at 8:06 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> >    I suggest focusing on asm.
>> > OK, I will switch gasm to asm, this does not work anyway.
>> > Having blocks that span multiple processes seems like over kill for a
>> smoother ?
>> > No, because it is a pain to have the math convolved with the parallel
>> decompositions strategy (ie, I can't tell an application how to partition
>> their problem). If an aggregate spans processor boundaries, which is fine
>> and needed, and let's say we have a pretty uniform problem, then if the
>> block gets split up, H is small in part of the domain and convergence could
>> suffer along processor boundaries.  And having the math change as the
>> parallel decomposition changes is annoying.
>> > (Major league overkill) in fact doesn't one want multiple blocks per
>> process, ie. pretty small blocks.
>> > No, it is just doing what would be done in serial.  If the cost of
>> moving the data across the processor is a problem then that is a tradeoff
>> to consider.
>> > And I think you are misunderstanding me.  There are lots of blocks per
>> process (the aggregates are say 3^D in size).  And many of the
>> aggregates/blocks along the processor boundary will be split between
>> processors, resulting is mall blocks and weak ASM PC on processor
>> boundaries.
>> > I can understand ASM not being general and not letting blocks span
>> processor boundaries, but I don't think the extra matrix communication
>> costs are a big deal (done just once) and the vector communication costs
>> are not bad, it probably does not include (too many) new processors to
>> communicate with.
>> >    Barry
>> > > On Jun 22, 2016, at 7:51 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> > > I'm trying to get block smoothers to work for gamg.  We (Garth) tried
>> this and got this error:
>> > >  - Another option is use '-pc_gamg_use_agg_gasm true' and use
>> '-mg_levels_pc_type gasm'.
>> > > Running in parallel, I get
>> > > First, what is the difference between asm and gasm?
>> > > Second, I need to fix this to get block smoothers. This used to
>> work.  Did we lose the capability to have blocks that span processor
>> subdomains?
>> > > gamg only aggregates across processor subdomains within one layer, so
>> maybe I could use one layer of overlap in some way?
>> > > Thanks,
>> > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160623/164cde29/attachment.html>
