[petsc-dev] consequences of setting KSP_NORM_TYPE to NONE
Sun Jun 12 23:16:14 CDT 2016
> On Jun 12, 2016, at 11:14 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>  Less code is, of course, always most appealing. Currently KSPConvergedDefault() has
>> if (normtype ==KSP_NORM_NONE) SETERRQ(PetscObjectComm((PetscObject)ksp),PETSC_ERR_ARG_WRONGSTATE,"Use KSPConvergedSkip() with KSPNormType of KSP_NORM_NONE");
>> presumably this is so that a user won't mistakenly set the convergence test after setting the norm to none and assume that the test will work? But does this really provide anything of value?
> I think it likely causes more confusion than it fixes.  And when do people explicitly set the convergence test to Default?
   Ok, I'll make a branch to simplify the code and have KSPConvergedDefault() just return on KSP_NORM_NONE
