[petsc-dev] Undefined symbol in SLEPc dylib (Haskell bindings, OSX)
Marco Zocca zocca.marco at gmail.com
Thu Jun 9 06:01:38 CDT 2016
All the KSPConv* symbols are defined (`nm -u ...` shows the blank string):
$ nm ${PETSC_DIR}/${PETSC_ARCH}/lib/libpetsc.3.7.2.dylib | grep KSPConv
000000000110a652 T _KSPConvergedDefault
0000000001109703 T _KSPConvergedDefaultCreate
000000000110b934 T _KSPConvergedDefaultDestroy
0000000001109a96 T _KSPConvergedDefaultSetUIRNorm
000000000110a074 T _KSPConvergedDefaultSetUMIRNorm
000000000106533d T _KSPConvergedLSQR
0000000001743280 D _KSPConvergedReasons
000000000173d300 s _KSPConvergedReasons_Shifted
000000000110920d T _KSPConvergedSkip
0000000001224e94 t _SNES_TR_KSPConverged_Destroy
00000000012248f6 t _SNES_TR_KSPConverged_Private
>> I encounter this bug when accessing the PETSc and SLEPc dynamic
>> library under OSX:
>> user specified .o/.so/.DLL could not be loaded
>> (dlopen($SLEPC_DIR/arch-darwin-c-debug/lib/libslepc.dylib, 5): Symbol
>> not found: _KSPConvergedReasons
>>   Referenced from: $SLEPC_DIR/arch-darwin-c-debug/lib/libslepc.dylib
>>   Expected in: flat namespace
>>  in $SLEPC_DIR/arch-darwin-c-debug/lib/libslepc.dylib)
>> Surely, enough, `nm -u` shows _KSPConvergedReasons as an undefined
>> symbol (see below).
>> I don't understand the reason of this behaviour since I first compile
>> with all the relevant PETSc and SLEPc headers and link against both
>> .dylibs.
>> Thank you in advance for any pointers,
>> Marco
>> $ nm -u libslepc.3.7.1.dylib | grep KSP
> What do you get for
>   nm -u libpetsc.3.7.1.dylib | grep KSPConv
>      Matt
