[petsc-dev] next broken in Travis-CI
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Tue Jun 7 15:23:26 CDT 2016
> On 7 Jun 2016, at 20:35, Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> wrote:
>> On 7 Jun 2016, at 20:55, Jed Brown <jed at jedbrown.org> wrote:
>> Lawrence, can you fix this or shall I?
> I'm travelling today so can't get to it til tomorrow. Please go ahead.
I found some wifi, maybe the attached?  I've mimicked the way MPI_COMBINER_DUP is treated.  I'm not sure what the define value should be (if it matters).
Lawrence
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160607/774150bb/attachment.obj>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160607/774150bb/attachment.sig>
