[petsc-dev] "make install" installs HTML files in $PREFIX/include
Tue Jun 7 12:02:41 CDT 2016
> On Jun 7, 2016, at 10:58 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> cc:ing petsc-dev
> Yeah - there are probably files that get installed - that shouldn't.
> [PETSC_DIR/bin probably needs cleaning up]
> Wrt build logs - I think sometimes its usefult to have them available
> from the prefix location.. [but perhaps thats not good from a
> packaging point of view]
> Satish
> On Tue, 7 Jun 2016, Lisandro Dalcin wrote:
>> BTW, there are a few other files that PETSc and SLEPc install, and I
>> think they should not be there (PKG_NAME is either petsc or slepc):
>> rm -f  $PREFIX/lib/$PKG_NAME/conf/files
   Are you referring to files such as pkg.conf.*  or pkg.gitcommit.* ?  What specific files do you not like?
  Barry
>> rm -f  $PREFIX/lib/$PKG_NAME/conf/*BuildInternal.cmake
>> Not sure about these, what do you think?
>> rm -f  $PREFIX/lib/$PKG_NAME/conf/*.log
>> rm -f  $PREFIX/lib/$PKG_NAME/conf/RDict.db
>> On 7 June 2016 at 12:34, Jose E. Roman <jroman at dsic.upv.es> wrote:
>>> My solution is not very nice, so if you find a better solution I will change it in SLEPc as well.
>>> Jose
>>>> El 7 jun 2016, a las 11:31, Lisandro Dalcin <dalcinl at gmail.com> escribió:
>>>> Satish, Jose just fixed this issue in SLEPc, here is the commit.
>>>> https://bitbucket.org/slepc/slepc/commits/d02c1aa057e872e40b6f07555da52f69747cb41d
>>>> We are guessing the same issue is in PETSc (unless we use the lite
>>>> tarball). Could you please check and fix if needed?
>>>> Lisandro Dalcin
>>>> Research Scientist
>>>> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
>>>> Extreme Computing Research Center (ECRC)
>>>> King Abdullah University of Science and Technology (KAUST)
>>>> http://ecrc.kaust.edu.sa/
>>>> 4700 King Abdullah University of Science and Technology
>>>> al-Khawarizmi Bldg (Bldg 1), Office # 0109
>>>> Thuwal 23955-6900, Kingdom of Saudi Arabia
>>>> http://www.kaust.edu.sa
>>>> Office Phone: +966 12 808-0459
