[petsc-dev] p4est configure error
Mark Adams mfadams at lbl.gov
Thu Jul 7 18:04:27 CDT 2016
On Fri, Jul 8, 2016 at 12:18 AM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> Interesting, you'd think that --disable-shared would be all that matters.
> Could you please send that configure.log for comparison?
> On July 7, 2016 5:14:13 PM CDT, Mark Adams <mfadams at lbl.gov> wrote:
> >Well, this did not work as you suspected ... FYI, it seems to work
> >with-debugging=0.
> >On Thu, Jul 7, 2016 at 11:13 PM, Satish Balay <balay at mcs.anl.gov>
> >wrote:
> >> /bin/sh ./libtool  --tag=CC   --mode=link cc  -no-ipo -g -O0   -o
> >> libb64/sc_b64enc libb64/libb64_sc_b64enc-b64enc.o ./src/libsc.la
> >-lgomp
> >> libtool: link: cc -no-ipo -g -O0 -o libb64/sc_b64enc
> >> libb64/libb64_sc_b64enc-b64enc.o  ./src/.libs/libsc.a
> >> /opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so -lrt -ldl -Wl,-rpath
> >> -Wl,/opt/gcc/5.2.0/snos/lib/../lib64 -Wl,-rpath
> >> For some reason libtool is converting "-lgomp" into
> >> "/opt/gcc/5.2.0/snos/lib/../lib64/libgomp.so" - and giving an ld
> >error.
> >> On my linux box - I see:
> >> /bin/sh ./libtool  --tag=CC   --mode=link mpicc  -g3   -o
> >libb64/sc_b64enc
> >> libb64/libb64_sc_b64enc-b64enc.o ./src/libsc.la -lgomp -lpthread -lz
> >-lm
> >> libtool: link: mpicc -g3 -o libb64/sc_b64enc
> >> libb64/libb64_sc_b64enc-b64enc.o  ./src/.libs/libsc.a -lgomp
> >-lpthread -lz
> >> -lm
> >> I don't really understand libtool - or this error..
> >> Satish
> >> On Thu, 7 Jul 2016, Tobin Isaac wrote:
> >> > Nope, different error: p4est autotools found an openmp library and
> >tried
> >> to link it, but there's a shared/static mismatch.  I'll try to get to
> >the
> >> bottom of this.
> >> > On July 7, 2016 3:27:23 PM CDT, Mark Adams <mfadams at lbl.gov> wrote:
> >> > >I nuked and ran this twice:
> >> > >1013  rm -fr arch-xc30-dbg64-intel
> >> > > 1014  ../arch-xc30-dbg64-intel.py
> >> > > 1015  h
> >> > > 1016  ../arch-xc30-dbg64-intel.py
> >> > >Same error.
> >> > >On Thu, Jul 7, 2016 at 9:36 PM, Satish Balay <balay at mcs.anl.gov>
> >wrote:
> >> > >> perhaps configure was not rerun - so a stale p4est was being
> >used..
> >> > >> Satish
> >> > >> > p4est.py automatically pulls from whatever p4est branch I call
> >> > >'petsc'
> >> > >> > in my repo, so I don't see how this problem persists if you
> >really
> >> > >> > nuked it.
> >> > >> > - Did you nuke the right directory?
> >> > >> > - Did you send me the right configure.log?
> >> > >> > - Is the new failure the same (the same stale p4est commit is
> >being
> >> > >> >   used)?
> >> > >> > On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams wrote:
> >> > >> > > It sounds like I have not merged your fix.  Should I pull
> >from
> >> > >master?
> >> > >> > > I have nuked this many times.
> >> > >> > > On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac
> >> > >> wrote:
> >> > >> > > > On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams
> >wrote:
> >> > >> > > > > p4est on Edison configures in w/o debugging, although I
> >have
> >> > >to run
> >> > >> > > > > configure twice.
> >> > >> > > > > But with debugging it fails.  I can not see any
> >difference
> >> > >between
> >> > >> the
> >> > >> > > > two
> >> > >> > > > > configures other than debugging.
> >> > >> > > > > Mark
> >> > >> > > > The log shows that you are configuring a p4est commit
> >(3d3e1)
> >> > >that is
> >> > >> > > > before the one I pushed specifically to avoid the fortran
> >> > >> > > > configuration error (f54bb3).  Please clear the git.p4est
> >> > >directory,
> >> > >> > > > and confirm that you are configuring with the current
> >'petsc'
> >> > >branch
> >> > >> > > > of p4est (`grep 'checking Point version' configure.log`
> >should
> >> > >show
> >> > >> > > > X.XXX-a9f22).
> >> > >> > > > Cheers,
> >> > >> > > >   Toby
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160708/ad151e19/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160708/ad151e19/attachment.obj>
