[petsc-dev] p4est configure error
Mark Adams mfadams at lbl.gov
Thu Jul 7 13:33:57 CDT 2016
It sounds like I have not merged your fix.  Should I pull from master?
I have nuked this many times.
On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac <tisaac at uchicago.edu> wrote:
> On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
> > p4est on Edison configures in w/o debugging, although I have to run
> > configure twice.
> > But with debugging it fails.  I can not see any difference between the
> two
> > configures other than debugging.
> > Mark
> The log shows that you are configuring a p4est commit (3d3e1) that is
> before the one I pushed specifically to avoid the fortran
> configuration error (f54bb3).  Please clear the git.p4est directory,
> and confirm that you are configuring with the current 'petsc' branch
> of p4est (`grep 'checking Point version' configure.log` should show
> X.XXX-a9f22).
> Cheers,
>   Toby
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160707/a33a734f/attachment.html>
