[petsc-dev] clash of --download-xxx with something in /usr/include /usr/local/include
Wed Jan 27 14:10:50 CST 2016
BTW: Wrt /usr/include [or /usr/lib] - one should not pass in this
location ever to configure [as its a default compiler search path].
Not sure if its possible for configure to check and error out. [ in
some cases - one needs these paths - if the compilers - c, c++,
fortran - do not share the same default paths..]
--with-package-include="" --with-package-lib="-lfoo"
Satish
On Wed, 27 Jan 2016, Satish Balay wrote:
> I guess something like the following might work:
> For any include file configure checks - it preserves the signature of
> its location and dependencies [and locadtions].  I think a
> 'preprocessed file' will have the relavent info/signature.
> And at the end of configure - these signatures [preprcessed files]
> have to be regenerated - and compare..
> Satish
> On Wed, 27 Jan 2016, Barry Smith wrote:
> >    When one runs for example --download-hd5f but there are hdf5 include files in /usr/include or /usr/local/include different compile stages, for example for different external packages, may use the wrong include files leading to very confusing failed builds.
> >    Is there any systematic tests we could add in configure that could detect this type of potential problem and error out or warn?
> >    Thanks
> >    Barry
