[petsc-dev] valgrind errors in the SUPERLU*
Sat Jan 16 21:36:47 CST 2016
  Sherry,
   I think the memory leak is our mistake. Thanks for checking the uninitialized copies
  Barry
> On Jan 16, 2016, at 2:04 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> The first leak is related to data structure for distributed sparse CSR matrix A (input).  How does the petsc interface free A's structure at the end of program?   There needs be a matching call like this:
>     Destroy_CompRowLoc_Matrix_dist(&A);
> when A is not needed anymore.
> I will go check all the MPI buffers.
> By the way, I have a question about valgrind.   Lately I have been chasing a possible memory corruption on  Cori at NERSC.  Valgrind gave LOTS OF internal system-related warnings, such as:
> ==39059== Conditional jump or move depends on uninitialised value(s)
> ==39059==    at 0xD5E336: __register_atfork (register-atfork.c:119)
> ==39059==    by 0xD5E418: __libc_pthread_init (libc_pthread_init.c:48)
> ==39059==    by 0x6629E1: __pthread_initialize_minimal (nptl-init.c:462)
> ==39059==    by 0xD14BDA: (below main) (libc-start.c:152)
> ==39059==
> ==39057==    by 0xD5E418: __libc_pthread_init (libc_pthread_init.c:48)
> ==39057==    by 0x6629E1: __pthread_initialize_minimal (nptl-init.c:462)
> ==39057==    by 0xD14BDA: (below main) (libc-start.c:152)
> ​This has nothing do do with my program.  Do you know a way to NOT to print those?   I got a huge file filled with these, hard to find out the real error.
> Sherry
> 2016-01-16 10:40 GMT-08:00 Barry Smith <bsmith at mcs.anl.gov>:
> Sherry,
>   We think there is a small memory leak in Superlu; could you check it?
> > ==11431== 40 bytes in 1 blocks are definitely lost in loss record 1 of 1
> > ==11431==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==11431==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==11431==    by 0x67834CA: dCreate_CompRowLoc_Matrix_dist (dutil_dist.c:61)
> > ==11431==    by 0x58C280D: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:405)
> > ==11431==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==11431==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==11431==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==11431==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==11431==    by 0x6025919: KSPSolve (itfunc.c:594)
> > ==11431==    by 0x61E538F: SNESSolve_NEWTONLS (ls.c:230)
> > ==11431==    by 0x6255E9C: SNESSolve (snes.c:3992)
> > ==11431==    by 0x40271F: main (ex19.c:160)
> > ==11431==
> > ==11430== 40 bytes in 1 blocks are definitely lost in loss record 1 of 1
> > ==11430==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==11430==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==11430==    by 0x67834CA: dCreate_CompRowLoc_Matrix_dist (dutil_dist.c:61)
> > ==11430==    by 0x58C280D: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:405)
> > ==11430==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==11430==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==11430==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==11430==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==11430==    by 0x6025919: KSPSolve (itfunc.c:594)
> > ==11430==    by 0x61E538F: SNESSolve_NEWTONLS (ls.c:230)
> > ==11430==    by 0x6255E9C: SNESSolve (snes.c:3992)
> > ==11430==    by 0x40271F: main (ex19.c:160)
> > ==11430==
> Another problem is that when running PETSc examples with Superlu we see valgrind warning messages about copying uninitialized data in MPI calls in superlu. This is cause by hypre allocating some buffer space, but only putting values in part of the buffer and then sending the entire buffer via MPI to some other process. Technically this is not an "error" if you never access the non initialized data on the receiver process but it makes valgrind unusable for finding TRUE memory issues (since the output is filled with false positives).
>    The issue could be fixed by either 1) initializing the complete buffer allocated (for example when it is malloced), then MPI won't see uninitialized data or better IMHO 2) send shorter messages that don't contain this part of the buffer that is never used anyway.
> Thanks
>   Barry
> ******* Testing: testexamples_SUPERLU_DIST_DATAFILESPATH *******
> 0a1,89
> > ==29986== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==29986==    at 0xE11ACDB: writev (writev.c:51)
> > ==29986==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==29986==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==29986==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==29986==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==29986==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==29986==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==29986==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==29986==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==29986==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==29986==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==29986==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==29986==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==29986==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==29986==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==29986==    by 0x405E42: main (ex10.c:316)
> > ==29986==  Address 0xf4d8318 is 8 bytes inside a block of size 131,072 alloc'd
> > ==29986==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==29986==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==29986==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==29986==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==29986==  Uninitialised value was created by a heap allocation
> > ==29986==
> > ==29987== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==29987==    at 0xE11ACDB: writev (writev.c:51)
> > ==29987==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==29987==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==29987==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==29987==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==29987==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==29987==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==29987==    by 0x67A8198: pdgstrs (pdgstrs.c:717)
> > ==29987==    by 0x6787E75: pdgssvx (pdgssvx.c:1260)
> > ==29987==    by 0x58BE3A4: MatSolve_SuperLU_DIST (superlu_dist.c:170)
> > ==29987==    by 0x591E6DB: MatSolve (matrix.c:3178)
> > ==29987==    by 0x5E58FA5: PCApply_LU (lu.c:213)
> > ==29987==    by 0x5DA1EC1: PCApply (precon.c:484)
> > ==29987==    by 0x6131991: KSP_PCApply (kspimpl.h:244)
> > ==29987==    by 0x613225F: KSPSolve_PREONLY (preonly.c:27)
> > ==29987==    by 0x6026542: KSPSolve (itfunc.c:651)
> > ==29987==    by 0x406122: main (ex10.c:336)
> > ==29987==  Address 0xfb20f38 is 8 bytes inside a block of size 152 alloc'd
> > ==29987==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==29987==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==29987==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==29987==    by 0x67A7A0F: pdgstrs (pdgstrs.c:580)
> > ==29987==  Uninitialised value was created by a heap allocation
> > ==29987==
> /sandbox/petsc/petsc.clone/src/ksp/ksp/examples/tutorials
> Possible problem with ex10_superlu_lu_2, diffs above
> 4a5,106
> > ==30097== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30097==    at 0xE11ACDB: writev (writev.c:51)
> > ==30097==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30097==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30097==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30097==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30097==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30097==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30097==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30097==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30097==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30097==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30097==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30097==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30097==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30097==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30097==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30097==    by 0x405E42: main (ex10.c:316)
> > ==30097==  Address 0xf625088 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30097==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30097==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30097==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30097==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30097==  Uninitialised value was created by a heap allocation
> > ==30097==
> > ==30098== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30098==    at 0xE11ACDB: writev (writev.c:51)
> > ==30098==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30098==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30098==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30098==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30098==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30098==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30098==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30098==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30098==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30098==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30098==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30098==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30098==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30098==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30098==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30098==    by 0x405E42: main (ex10.c:316)
> > ==30098==  Address 0xf619a88 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30098==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30098==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30098==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30098==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30098==  Uninitialised value was created by a heap allocation
> > ==30098==
> 8a111,314
> > ==30150== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30150==    at 0xE11ACDB: writev (writev.c:51)
> > ==30150==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30150==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30150==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30150==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30150==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30150==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30150==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30150==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30150==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30150==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30150==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30150==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30150==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30150==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30150==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30150==    by 0x405E42: main (ex10.c:316)
> > ==30150==  Address 0xf623888 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30150==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30150==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30150==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30150==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30152== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30152==    at 0xE11ACDB: writev (writev.c:51)
> > ==30152==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30152==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30152==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30152==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30152==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30150==  Uninitialised value was created by a heap allocation
> > ==30152==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30150==
> > ==30152==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30152==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30152==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30152==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30152==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30152==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30152==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30152==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30152==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30152==    by 0x405E42: main (ex10.c:316)
> > ==30152==  Address 0xf61cff8 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30152==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30152==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30152==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30152==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30152==  Uninitialised value was created by a heap allocation
> > ==30152==
> > ==30151== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30151==    at 0xE11ACDB: writev (writev.c:51)
> > ==30151==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30151==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30151==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30151==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30151==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30151==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30151==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30151==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30151==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30151==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30151==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30151==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30151==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30151==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30151==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30151==    by 0x405E42: main (ex10.c:316)
> > ==30151==  Address 0xf6183c8 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30151==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30151==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30151==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30151==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30151==  Uninitialised value was created by a heap allocation
> > ==30151==
> > ==30153== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30153==    at 0xE11ACDB: writev (writev.c:51)
> > ==30153==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30153==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30153==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30153==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30153==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30153==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30153==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30153==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30153==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30153==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30153==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30153==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30153==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30153==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30153==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30153==    by 0x405E42: main (ex10.c:316)
> > ==30153==  Address 0xf617728 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30153==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30153==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30153==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30153==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30153==  Uninitialised value was created by a heap allocation
> > ==30153==
> 12a319,624
> > ==30207== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30207==    at 0xE11ACDB: writev (writev.c:51)
> > ==30207==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30207==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30207==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30207==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30207==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30207==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30207==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30207==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30207==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30207==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30207==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30207==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30207==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30207==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30207==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30207==    by 0x405E42: main (ex10.c:316)
> > ==30207==  Address 0xf6202b8 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30207==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30207==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30207==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30207==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30207==  Uninitialised value was created by a heap allocation
> > ==30207==
> > ==30205== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30205==    at 0xE11ACDB: writev (writev.c:51)
> > ==30205==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30205==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30205==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30205==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30205==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30205==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30205==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30205==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30205==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30205==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30205==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30205==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30205==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30205==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30205==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30205==    by 0x405E42: main (ex10.c:316)
> > ==30205==  Address 0xf61b928 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30205==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30205==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30205==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30205==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30205==  Uninitialised value was created by a heap allocation
> > ==30205==
> > ==30208== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30208==    at 0xE11ACDB: writev (writev.c:51)
> > ==30208==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30208==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30208==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30208==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30208==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30208==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30208==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30208==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30208==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30208==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30208==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30208==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30208==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30208==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30208==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30208==    by 0x405E42: main (ex10.c:316)
> > ==30208==  Address 0xf6142f8 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30208==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30208==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30208==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30208==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30208==  Uninitialised value was created by a heap allocation
> > ==30208==
> > ==30206== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30206==    at 0xE11ACDB: writev (writev.c:51)
> > ==30206==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30206==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30206==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30206==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30206==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30206==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30206==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30206==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30206==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30206==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30206==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30206==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30206==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30206==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30206==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30206==    by 0x405E42: main (ex10.c:316)
> > ==30206==  Address 0xf6164f8 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30206==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30206==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30206==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30206==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30206==  Uninitialised value was created by a heap allocation
> > ==30206==
> > ==30203== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30203==    at 0xE11ACDB: writev (writev.c:51)
> > ==30203==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30203==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30203==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30203==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30203==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30203==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30203==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30203==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30203==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30203==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30203==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30203==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30203==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30203==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30203==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30203==    by 0x405E42: main (ex10.c:316)
> > ==30203==  Address 0xf6229c8 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30203==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30203==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30203==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30203==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30203==  Uninitialised value was created by a heap allocation
> > ==30203==
> > ==30204== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30204==    at 0xE11ACDB: writev (writev.c:51)
> > ==30204==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30204==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30204==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30204==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30204==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30204==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30204==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30204==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30204==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30204==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30204==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30204==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30204==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30204==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30204==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30204==    by 0x405E42: main (ex10.c:316)
> > ==30204==  Address 0xf617008 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30204==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30204==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30204==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30204==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30204==  Uninitialised value was created by a heap allocation
> > ==30204==
> 16a629,1036
> > ==30262== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30262==    at 0xE11ACDB: writev (writev.c:51)
> > ==30262==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30262==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30262==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30262==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30262==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30262==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30262==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30262==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30262==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30262==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30262==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30262==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30262==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30262==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30262==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30262==    by 0x405E42: main (ex10.c:316)
> > ==30262==  Address 0xf61c2b8 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30262==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30262==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30262==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30262==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30262==  Uninitialised value was created by a heap allocation
> > ==30262==
> > ==30260== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30260==    at 0xE11ACDB: writev (writev.c:51)
> > ==30260==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30260==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30260==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30260==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30260==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30260==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30260==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30260==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30260==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30260==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30260==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30260==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30260==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30260==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30260==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30260==    by 0x405E42: main (ex10.c:316)
> > ==30260==  Address 0xf61ed28 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30260==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30260==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30260==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30260==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30260==  Uninitialised value was created by a heap allocation
> > ==30260==
> > ==30258== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30258==    at 0xE11ACDB: writev (writev.c:51)
> > ==30258==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30258==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30258==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30258==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30258==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30258==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30258==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30258==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30258==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30258==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30258==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30258==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30258==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30258==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30258==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30258==    by 0x405E42: main (ex10.c:316)
> > ==30258==  Address 0xf61a368 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30258==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30258==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30258==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30258==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30258==  Uninitialised value was created by a heap allocation
> > ==30258==
> > ==30256== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30256==    at 0xE11ACDB: writev (writev.c:51)
> > ==30256==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30256==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30256==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30256==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30256==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30256==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30256==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30256==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30256==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30256==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30256==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30256==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30256==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30256==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30256==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30256==    by 0x405E42: main (ex10.c:316)
> > ==30256==  Address 0xf621318 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30256==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30256==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30256==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30256==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30256==  Uninitialised value was created by a heap allocation
> > ==30256==
> > ==30263== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30263==    at 0xE11ACDB: writev (writev.c:51)
> > ==30263==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30263==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30263==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30263==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30263==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30263==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30263==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30263==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30263==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30263==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30263==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30263==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30263==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30263==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30263==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30263==    by 0x405E42: main (ex10.c:316)
> > ==30263==  Address 0xf612b98 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30263==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30263==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30263==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30263==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30263==  Uninitialised value was created by a heap allocation
> > ==30263==
> > ==30261== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30261==    at 0xE11ACDB: writev (writev.c:51)
> > ==30261==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30261==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30261==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30261==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30261==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30261==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30261==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30261==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30261==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30261==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30261==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30261==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30261==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30261==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30261==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30261==    by 0x405E42: main (ex10.c:316)
> > ==30261==  Address 0xf612f58 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30261==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30261==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30261==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30261==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30261==  Uninitialised value was created by a heap allocation
> > ==30261==
> > ==30259== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30259==    at 0xE11ACDB: writev (writev.c:51)
> > ==30259==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30259==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30259==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30259==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30259==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30259==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30259==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30259==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30259==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30259==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30259==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30259==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30259==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30259==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30259==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30259==    by 0x405E42: main (ex10.c:316)
> > ==30259==  Address 0xf615468 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30259==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30259==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30259==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30259==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30259==  Uninitialised value was created by a heap allocation
> > ==30259==
> > ==30257== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30257==    at 0xE11ACDB: writev (writev.c:51)
> > ==30257==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30257==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30257==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30257==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30257==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30257==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30257==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30257==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30257==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30257==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30257==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30257==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30257==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30257==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30257==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30257==    by 0x405E42: main (ex10.c:316)
> > ==30257==  Address 0xf615c38 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30257==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30257==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30257==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30257==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30257==  Uninitialised value was created by a heap allocation
> > ==30257==
> 20a1041,1484
> > ==30314== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30314==    at 0xE11ACDB: writev (writev.c:51)
> > ==30314==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30314==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30314==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30314==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30314==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30314==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30314==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30314==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30314==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30314==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30314==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30314==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30314==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30314==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30314==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30314==    by 0x405E42: main (ex10.c:316)
> > ==30314==  Address 0xf61a5e8 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30314==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30314==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30314==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30314==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30314==  Uninitialised value was created by a heap allocation
> > ==30314==
> > ==30308== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30308==    at 0xE11ACDB: writev (writev.c:51)
> > ==30308==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30308==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30308==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30308==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30308==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30308==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30308==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30308==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30308==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30308==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30308==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30308==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30308==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30308==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30308==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30308==    by 0x405E42: main (ex10.c:316)
> > ==30308==  Address 0xf60ee88 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30308==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30308==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30308==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30308==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30308==  Uninitialised value was created by a heap allocation
> > ==30308==
> > ==30311== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30311==    at 0xE11ACDB: writev (writev.c:51)
> > ==30311==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30311==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30311==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30311==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30311==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30311==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30311==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30311==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30311==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30311==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30311==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30311==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30311==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30311==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30311==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30311==    by 0x405E42: main (ex10.c:316)
> > ==30311==  Address 0xf60b8e8 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30311==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30311==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30311==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30311==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30311==  Uninitialised value was created by a heap allocation
> > ==30311==
> > ==30315== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30315==    at 0xE11ACDB: writev (writev.c:51)
> > ==30315==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30315==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30315==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30315==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30315==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30315==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30315==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30315==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30315==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30315==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30315==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30315==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30315==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30315==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30315==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30315==    by 0x405E42: main (ex10.c:316)
> > ==30315==  Address 0xf611828 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30315==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30315==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30315==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30315==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30315==  Uninitialised value was created by a heap allocation
> > ==30315==
> > ==30309== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30309==    at 0xE11ACDB: writev (writev.c:51)
> > ==30309==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30309==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30309==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30309==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30309==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30309==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30309==    by 0x67A8198: pdgstrs (pdgstrs.c:717)
> > ==30309==    by 0x6787E75: pdgssvx (pdgssvx.c:1260)
> > ==30309==    by 0x58BE3A4: MatSolve_SuperLU_DIST (superlu_dist.c:170)
> > ==30309==    by 0x591E6DB: MatSolve (matrix.c:3178)
> > ==30309==    by 0x5E58FA5: PCApply_LU (lu.c:213)
> > ==30312== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30309==    by 0x5DA1EC1: PCApply (precon.c:484)
> > ==30309==    by 0x6131991: KSP_PCApply (kspimpl.h:244)
> > ==30309==    by 0x613225F: KSPSolve_PREONLY (preonly.c:27)
> > ==30309==    by 0x6026542: KSPSolve (itfunc.c:651)
> > ==30309==    by 0x6014529: PCApply_Redundant (redundant.c:198)
> > ==30309==  Address 0xf772038 is 8 bytes inside a block of size 520 alloc'd
> > ==30309==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30309==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30309==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30309==    by 0x67A7A0F: pdgstrs (pdgstrs.c:580)
> > ==30309==    by 0x406122: main (ex10.c:336)
> > ==30309==  Uninitialised value was created by a heap allocation
> > ==30309==
> > ==30310== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30310==    at 0xE11ACDB: writev (writev.c:51)
> > ==30313== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30313==    at 0xE11ACDB: writev (writev.c:51)
> > ==30313==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30313==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30313==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30313==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30313==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30313==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30313==    by 0x67A8198: pdgstrs (pdgstrs.c:717)
> > ==30313==    by 0x6787E75: pdgssvx (pdgssvx.c:1260)
> > ==30313==    by 0x58BE3A4: MatSolve_SuperLU_DIST (superlu_dist.c:170)
> > ==30313==    by 0x591E6DB: MatSolve (matrix.c:3178)
> > ==30313==    by 0x5E58FA5: PCApply_LU (lu.c:213)
> > ==30313==    by 0x5DA1EC1: PCApply (precon.c:484)
> > ==30313==    by 0x6131991: KSP_PCApply (kspimpl.h:244)
> > ==30313==    by 0x613225F: KSPSolve_PREONLY (preonly.c:27)
> > ==30313==    by 0x6026542: KSPSolve (itfunc.c:651)
> > ==30313==    by 0x6014529: PCApply_Redundant (redundant.c:198)
> > ==30313==  Address 0xf7904c8 is 8 bytes inside a block of size 712 alloc'd
> > ==30313==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30313==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30313==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30313==    by 0x67A7A0F: pdgstrs (pdgstrs.c:580)
> > ==30313==    by 0x406122: main (ex10.c:336)
> > ==30313==  Uninitialised value was created by a heap allocation
> > ==30313==
> > ==30310==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30310==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30310==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30310==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30310==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30310==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30310==    by 0x67A8198: pdgstrs (pdgstrs.c:717)
> > ==30310==    by 0x6787E75: pdgssvx (pdgssvx.c:1260)
> > ==30310==    by 0x58BE3A4: MatSolve_SuperLU_DIST (superlu_dist.c:170)
> > ==30312==    at 0xE11ACDB: writev (writev.c:51)
> > ==30312==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30310==    by 0x591E6DB: MatSolve (matrix.c:3178)
> > ==30312==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30310==    by 0x5E58FA5: PCApply_LU (lu.c:213)
> > ==30312==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30312==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30310==    by 0x5DA1EC1: PCApply (precon.c:484)
> > ==30312==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30310==    by 0x6131991: KSP_PCApply (kspimpl.h:244)
> > ==30312==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30310==    by 0x613225F: KSPSolve_PREONLY (preonly.c:27)
> > ==30312==    by 0x67A8198: pdgstrs (pdgstrs.c:717)
> > ==30310==    by 0x6026542: KSPSolve (itfunc.c:651)
> > ==30312==    by 0x6787E75: pdgssvx (pdgssvx.c:1260)
> > ==30312==    by 0x58BE3A4: MatSolve_SuperLU_DIST (superlu_dist.c:170)
> > ==30310==    by 0x6014529: PCApply_Redundant (redundant.c:198)
> > ==30312==    by 0x591E6DB: MatSolve (matrix.c:3178)
> > ==30312==    by 0x5E58FA5: PCApply_LU (lu.c:213)
> > ==30312==    by 0x5DA1EC1: PCApply (precon.c:484)
> > ==30312==    by 0x6131991: KSP_PCApply (kspimpl.h:244)
> > ==30310==  Address 0xf7908f8 is 8 bytes inside a block of size 712 alloc'd
> > ==30312==    by 0x613225F: KSPSolve_PREONLY (preonly.c:27)
> > ==30312==    by 0x6026542: KSPSolve (itfunc.c:651)
> > ==30310==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30312==    by 0x6014529: PCApply_Redundant (redundant.c:198)
> > ==30310==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30312==  Address 0xfb11898 is 8 bytes inside a block of size 520 alloc'd
> > ==30310==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30312==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30310==    by 0x67A7A0F: pdgstrs (pdgstrs.c:580)
> > ==30312==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30312==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30312==    by 0x67A7A0F: pdgstrs (pdgstrs.c:580)
> > ==30312==    by 0x406122: main (ex10.c:336)
> > ==30312==  Uninitialised value was created by a heap allocation
> > ==30310==    by 0x406122: main (ex10.c:336)
> > ==30310==  Uninitialised value was created by a heap allocation
> > ==30312==
> > ==30310==
> 24a1489,1692
> > ==30367== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30367==    at 0xE11ACDB: writev (writev.c:51)
> > ==30371== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30367==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30367==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30367==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30367==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30367==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30367==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30367==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30367==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30367==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30367==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30367==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30367==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30367==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30367==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30367==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30367==    by 0x405E42: main (ex10.c:316)
> > ==30371==    at 0xE11ACDB: writev (writev.c:51)
> > ==30367==  Address 0xf608dc8 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30367==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30367==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30367==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30367==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30367==  Uninitialised value was created by a heap allocation
> > ==30367==
> > ==30371==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30371==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30371==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30371==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30371==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30371==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30371==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30371==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30371==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30371==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30371==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30371==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30371==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30371==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30371==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30371==    by 0x405E42: main (ex10.c:316)
> > ==30371==  Address 0xf6067a8 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30371==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30371==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30371==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30371==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30371==  Uninitialised value was created by a heap allocation
> > ==30371==
> > ==30374== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30374==    at 0xE11ACDB: writev (writev.c:51)
> > ==30374==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30374==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30374==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30374==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30370== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30370==    at 0xE11ACDB: writev (writev.c:51)
> > ==30374==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30370==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30370==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30370==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30370==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30370==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30370==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30370==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30370==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30370==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30370==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30370==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30370==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30370==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30370==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30370==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30370==    by 0x405E42: main (ex10.c:316)
> > ==30370==  Address 0xf5fc5e8 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30370==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30370==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30370==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30370==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30370==  Uninitialised value was created by a heap allocation
> > ==30370==
> > ==30374==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30374==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30374==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30374==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30374==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30374==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30374==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30374==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30374==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30374==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30374==    by 0x405E42: main (ex10.c:316)
> > ==30374==  Address 0xf5fa468 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30374==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30374==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30374==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30374==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30374==  Uninitialised value was created by a heap allocation
> > ==30374==
> 28a1697,1909
> > ==30420== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30420==    at 0xE11ACDB: writev (writev.c:51)
> > ==30420==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30420==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30420==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30420==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30420==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30420==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30420==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30420==    by 0x67A0BCF: pdgstrf (pdgstrf.c:981)
> > ==30420==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30420==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30420==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30420==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30420==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30420==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30420==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30420==    by 0x405E42: main (ex10.c:316)
> > ==30420==  Address 0xf5f10b8 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30420==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30420==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30420==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30420==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30420==  Uninitialised value was created by a heap allocation
> > ==30420==
> > ==30423== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30423==    at 0xE11ACDB: writev (writev.c:51)
> > ==30423==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30423==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30423==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30423==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30423==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30423==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30423==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30423==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30423==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30423==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30423==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30423==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30423==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30423==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30423==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30423==    by 0x405E42: main (ex10.c:316)
> > ==30423==  Address 0xf5dd228 is 8 bytes inside a block of size 131,072 alloc'd
> > ==30423==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30423==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30423==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30423==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30423==  Uninitialised value was created by a heap allocation
> > ==30423==
> > ==30427== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30427==    at 0xE11ACDB: writev (writev.c:51)
> > ==30427==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30427==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30427==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30427==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30427==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30427==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30427==    by 0x67A605A: pdgstrf2_trsm (pdgstrf2.c:199)
> > ==30427==    by 0x67A11C7: pdgstrf (pdgstrf.c:1084)
> > ==30427==    by 0x6787708: pdgssvx (pdgssvx.c:1109)
> > ==30427==    by 0x58C32E4: MatLUFactorNumeric_SuperLU_DIST (superlu_dist.c:421)
> > ==30427==    by 0x591B10A: MatLUFactorNumeric (matrix.c:2946)
> > ==30427==    by 0x5E581F6: PCSetUp_LU (lu.c:164)
> > ==30427==    by 0x5DA8CFA: PCSetUp (precon.c:984)
> > ==30427==    by 0x6023C6F: KSPSetUp (itfunc.c:390)
> > ==30427==    by 0x6013E35: PCSetUp_Redundant (redundant.c:171)
> > ==30427==    by 0x405E42: main (ex10.c:316)
> > ==30427==  Address 0xf5d79d8 is 72 bytes inside a block of size 131,072 alloc'd
> > ==30427==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30427==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30427==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30427==    by 0x67A022E: pdgstrf (pdgstrf.c:737)
> > ==30427==  Uninitialised value was created by a heap allocation
> > ==30427==
> > ==30424== Syscall param writev(vector[...]) points to uninitialised byte(s)
> > ==30424==    at 0xE11ACDB: writev (writev.c:51)
> > ==30424==    by 0xDAC9596: MPL_large_writev (mplsock.c:32)
> > ==30424==    by 0xDAB8DC9: MPIDU_Sock_writev (sock_immed.i:610)
> > ==30424==    by 0xDA739CD: MPIDI_CH3_iSendv (ch3_isendv.c:84)
> > ==30424==    by 0xDA43948: MPIDI_CH3_EagerContigIsend (ch3u_eager.c:556)
> > ==30424==    by 0xDA58574: MPID_Isend (mpid_isend.c:138)
> > ==30424==    by 0xD930ED8: PMPI_Isend (isend.c:125)
> > ==30424==    by 0x67A8198: pdgstrs (pdgstrs.c:717)
> > ==30424==    by 0x6787E75: pdgssvx (pdgssvx.c:1260)
> > ==30424==    by 0x58BE3A4: MatSolve_SuperLU_DIST (superlu_dist.c:170)
> > ==30424==    by 0x591E6DB: MatSolve (matrix.c:3178)
> > ==30424==    by 0x5E58FA5: PCApply_LU (lu.c:213)
> > ==30424==    by 0x5DA1EC1: PCApply (precon.c:484)
> > ==30424==    by 0x6131991: KSP_PCApply (kspimpl.h:244)
> > ==30424==    by 0x613225F: KSPSolve_PREONLY (preonly.c:27)
> > ==30424==    by 0x6026542: KSPSolve (itfunc.c:651)
> > ==30424==    by 0x6014529: PCApply_Redundant (redundant.c:198)
> > ==30424==  Address 0xf745788 is 8 bytes inside a block of size 336 alloc'd
> > ==30424==    at 0x4C2B6CD: malloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
> > ==30424==    by 0x67B5CBD: superlu_malloc_dist (memory.c:108)
> > ==30424==    by 0x6785666: doubleMalloc_dist (dmemory_dist.c:145)
> > ==30424==    by 0x67A7A0F: pdgstrs (pdgstrs.c:580)
> > ==30424==    by 0x406122: main (ex10.c:336)
> > ==30424==  Uninitialised value was created by a heap allocation
> > ==30424==
> Possible problem with ex10_superlu_dist_redundant, diffs above
> ******* Testing: testexamples_CHACO *******
