[petsc-dev] Contribution proposal about the application of PCShell as left and right preconditioner
Thu Jan 14 13:34:29 CST 2016
  Patch is now in master.
   Thanks for your contribution
   Barry
> On Jan 13, 2016, at 1:32 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Sylvain,
>   Thank you. I have put your patch into the branch barry/Sylvain-gmres-symmetric and merged into next for testing.
>   Barry
>> On Jan 9, 2016, at 3:06 PM, Sylvain Mercier <sylvainmercier85 at gmail.com> wrote:
>> Dear PETSc team,
>> During my phd thesis, I have worked on solving sequences of linear
>> systems with slowly varying matrices using GMRES(restart). In
>> particular, I have developed a preconditioning technique to improve
>> the action of an existing "first-level preconditioner". This new
>> method is usually applied as right preconditioner with a PCShell, although the first preconditioner is applied on the left.
>> That is why I have developed routines in PETSc to be able to apply simultaneously a left and a right PCShells when we use a PC_SYMMETRIC PCSIDE. In fact, I have add two routines: PCShellSetApplySymmetricLeft and PCShellSetApplySymmetricRight (similarly to the routine PCShellSetApply).
>> Moreover, I have added the possibility to use a PC_SYMMETRIC preconditioner within GMRES.
>> I gently request your position on the integration of these developments in PETSc. I have some problems to provide a pull-request via a fork so I propose a patch. Let me know if you want extra integration work.
>> Best regards,
>> Sylvain.
>> <0001-Application-symmetric-pchell-and-symmetric-pc-within.patch>
