[petsc-dev] snes_monitor_residual
Mark Adams mfadams at lbl.gov
Thu Dec 22 08:02:30 CST 2016
>> #PETSc Option Table entries:
>> -dm_view hdf5:res.h5
>> -snes_monitor_residual hdf5:res.h5::append
>> ierr = DMViewFromOptions(ctx->dm,NULL,"-dm_view");CHKERRQ(ierr);
> 1) You need this in the code. Its in all my examples.
> 2) Did you put it before the vec views? Otherwise, it need 'append'.
The vec views are inside of SNES. I added this code before TSSolve and it
did not change anything.
I do not see an example with snes_monitor_residual.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161222/f3431d2a/attachment.html>
