[petsc-dev] Configure fails on macOS with MKL
Jeff Hammond jeff.science at gmail.com
Wed Dec 21 10:39:30 CST 2016
Is Petsc build system not capable of running "find" on $MKLROOT as a hedge
against subdirectories reorganization?
At least with Intel compilers, "-mkl" is the easy button unless you're
trying to get threaded BLAS/LAPACK with ScaLAPACK.
Jeff
On Wed, Dec 21, 2016 at 7:37 AM Pierre Jolivet <Pierre.Jolivet at enseeiht.fr>
wrote:
> On Wed, 21 Dec 2016 09:17:33 -0600, Satish Balay wrote:
> > I've added $MKLROOT/lib/ to search path for MKL. Thanks for the
> > report.
> https://bitbucket.org/petsc/petsc/commits/7fe016461159234c29eaa106eb46d0bf81683f36
> Thanks.
> > Wrt libiomp5.dylib - its an intel compiler library - so its found
> > when
> > using icc,icpc [as you describe below].
> > I guess it doesn't work when building with clang?
> > Intel MKL advisor is the authoritative tool for such checks..
> Yet another bug'd Intel "software"...
> > https://software.intel.com/en-us/articles/intel-mkl-link-line-advisor/
> > it says:
> >  -L${MKLROOT}/lib -Wl,-rpath,${MKLROOT}/lib -lmkl_intel_lp64
> > -lmkl_intel_thread -lmkl_core -lmkl_blacs_mpich_lp64 -liomp5
> > -lpthread
> > -lm -ldl
> > So it suggests using -liomp5 - but doesn't say - its not a clang
> > library. Not sure how to deal with this automatically.
> > Your current approach of using LDFLAGS is appropriate [workarround].
> It should be reachable by the linker in most cases in one of the
> following folder:
> ${MKLROOT}/../compiler/[os.path.join('lib','64'),os.path.join('lib','ia64'),os.path.join('lib','em64t'),os.path.join('lib','intel64'),'lib','64','ia64','em64t','intel64',os.path.join('lib','32'),os.path.join('lib','ia32'),'32','ia32','']
> But there might be a more appropriate (or less ugly) way to go.
> Thanks.
> > Satish
> > On Wed, 21 Dec 2016, Pierre Jolivet wrote:
> >> Hello,
> >> There are some issues when using (most recent versions of) the MKL
> >> on macOS:
> >> 1) the correct path to libmkl_*.dylib is now $MKLROOT/lib/, but this
> >> is not taken into account by the build system
> >> diff --git a/config/BuildSystem/config/packages/BlasLapack.py
> >> b/config/BuildSystem/config/packages/BlasLapack.py
> >> index 43597e2..017ed12 100644
> >> --- a/config/BuildSystem/config/packages/BlasLapack.py
> >> +++ b/config/BuildSystem/config/packages/BlasLapack.py
> >> @@ -217,7 +217,7 @@ class Configure(config.package.Package):
> >>          mkl_blacs_32=[]
> >>        if useCPardiso or usePardiso:
> >>          self.logPrintBox('BLASLAPACK: Looking for Multithreaded MKL
> >> for C/Pardiso')
> >> -        for libdir in
> [os.path.join('lib','64'),os.path.join('lib','ia64'),os.path.join('lib','em64t'),os.path.join('lib','intel64'),'64','ia64','em64t','intel64',
> >> +        for libdir in
> [os.path.join('lib','64'),os.path.join('lib','ia64'),os.path.join('lib','em64t'),os.path.join('lib','intel64'),'64','ia64','em64t','lib','intel64',
> >> os.path.join('lib','32'),os.path.join('lib','ia32'),'32','ia32','']:
> >>            if not os.path.exists(os.path.join(dir,libdir)):
> >>              self.logPrint('MKL Path not found.. skipping:
> >> '+os.path.join(dir,libdir))
> >> 2) Once this is fixed, it is assumed that libiomp5.dylib is in the
> >> same folder as libmkl_intel_thread.dylib (which is wrong), or at least
> >> visible to the linker. Thus, the configure will fail because it can’t
> >> find libiomp5.dylib, unless explicitly using —CXX=icpc and —CC=icc, or
> >> —LDFLAGS=-L${PATH_TO_LIBIOMP5}
> >> I don’t know if you care enough to fix this (I’m guessing there
> >> aren’t that many macOS users compiling PETSc with MKL support but
> >> without the Intel compilers), but just in case…
> >> Thanks,
> >> Pierre
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161221/79d5f4c1/attachment.html>
