[petsc-dev] with-fortran-interfaces
Pierre Jolivet Pierre.Jolivet at enseeiht.fr
Sun Dec 11 16:25:56 CST 2016
Alright, I'll use Sowing then!
Thank you very much.
On Sun, 11 Dec 2016 16:20:02 -0600, Barry Smith wrote:
> When using git versions of PETSc you cannot use this option
>   --with-sowing=0
>    unless you turn off Fortran with --with-fc=0
>    Sowing builds much of the infrastructure for Fortran.
>   Barry
>> On Dec 11, 2016, at 4:14 PM, Pierre Jolivet
>> <Pierre.Jolivet at enseeiht.fr> wrote:
>> On Sun, 11 Dec 2016 16:02:02 -0600, Barry Smith wrote:
>>> I don't think this has anything to do with MUMPS.
>> For sure, otherwise I would have bugged my teammates (who are
>> developing MUMPS) instead of you.
>>> Seems the Intel ifort
>>> ifort (IFORT) 17.0.0 20160721
>>> doesn't like our Fortran modules. I'll try to reproduce this and
>>> determine the problem.
>> Actually, I just realized that I tried to fix the issue myself
>> first. I have re-uploaded make.log. The initial error was (correctly
>> shown here http://jolivet.perso.enseeiht.fr/make.log):
>> petscsysmod.F(49): #error: can't find include file:
>> ../src/sys/f90-mod/ftn-auto-interfaces/petscsys.h90
>> But I noticed that the file src/sys/f90-mod/petscsys.h90 exists (no
>> "ftn-auto-interfaces"), so I did a quick `find . -name *mod.F -type f
>> -print0 | xargs -0 sed -i 's/ftn-auto-interfaces\///g'` and I ended up
>> with the old error instead.
>> Sorry for the confusion.
>> Thanks.
>>>   Barry
>>>> On Dec 11, 2016, at 3:48 PM, Pierre Jolivet
>>>> On Sun, 11 Dec 2016 15:17:14 -0600, Matthew Knepley wrote:
>>>>> On Sun, Dec 11, 2016 at 3:12 PM, Pierre Jolivet  wrote:
>>>>>> Hello,
>>>>>> It seems --with-fortran-interfaces is no more.
>>>>>> Any clue on how to compile packages which require a Fortran
>>>>>> compiler (e.g., MUMPS), without having PETSc compile the Fortran
>>>>>> interfaces?
>>>>> That flag just compiled the F90 interface. Now they are built by
>>>>> default.
>>>> That's too bad for systems like mine which fail to build the PETSc
>>>> interfaces but have no problem whatsoever compiling MUMPS.
>>>> Following Barry's message, here are my logs (large files, sorry):
>>>> http://jolivet.perso.enseeiht.fr/configure.log
>>>> It's been at least a good couple of months since I've been able to
>>>> compile the Fortran interfaces, and --with-fortran-interfaces=0 was
>>>> the easiest fix I could find. Now that it's gone, it looks like I'll
>>>> have to bother you with this.
>>>> Thanks for looking.
>>>> PS: this is from a clean dir (git clean -x -f -d)
>>>>>  Matt
>>>>>> Thanks in advance.
