[petsc-dev] PETSc BILU in parallel
Jed Brown jed at jedbrown.org
Fri Dec 9 10:52:38 CST 2016
Paolo Orsini <paolo.orsini at gmail.com> writes:
> Hi Jed,
> In PETSc a parallel implement implementation of the BILU(k) pre-conditioner
> is not available.
> Something seems to be available through HYPREE (Euclide in particular),
> which we know is interfaced with PETSc. However, we can't find a way to set
> this up: there seem to be no options in the database pertaining to Euclid.
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCHYPRE.html
> We are just wondered what's the status of the interface between  PETSc and
> HYPREE-EUCLIDE,... Or if you could point us out towards to the right
> direction. Do you know any other library interfaced with PETSc that makes a
> parallel BILU(0) available?
https://bitbucket.org/petsc/petsc/commits/22b6d1ca80e4f79123036fb6afd7eb4463b3692a
Barry removed the Euclid interface due to bugs and its apparent lack of
maintenance.  I suppose you could test by using an old PETSc (3.5).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161209/68d725fb/attachment.sig>
