[petsc-dev] Algebraic Multigrid
Mark Adams mfadams at lbl.gov
Wed Aug 17 17:04:00 CDT 2016
On Wed, Aug 17, 2016 at 4:33 PM, Ari Rappaport <arir at vosssci.com> wrote:
> Ok, thank you. So for AMS there is the option to use
> PCHYPRESetEdgeConstantVectors. Is there any example somewhere of how this
> function is supposed to be used?
This is probably a wrapper for a hypre method so I'd check the hypre docs.
> Also, it is possible to set the pc type to hypre inside the code? e.g.
> PCSetType(pc, <HYPRE>)
yes
> -Ari
> From: "Satish Balay" <balay at mcs.anl.gov>
> To: "Ari Rappaport" <arir at vosssci.com>
> Cc: "petsc-dev" <petsc-dev at mcs.anl.gov>
> Sent: Wednesday, August 17, 2016 1:11:43 PM
> Subject: Re: [petsc-dev] Algebraic Multigrid
> balay at asterix /home/balay/petsc/src/ksp/ksp/examples/tutorials (master=)
> $ ./ex2 -pc_type hypre -h |grep pc_hypre_type
>   -pc_hypre_type <boomeramg> (choose one of) pilut parasails boomeramg ams
> (PCHYPRESetType)
> Satish
> On Wed, 17 Aug 2016, Ari Rappaport wrote:
> > Hi again,
> > I am having a problem with the database option -pc_hypre_set_type ams
> along with -pc_type hypre. When I run my simulation I get the message
> "Option left: name:-pc_hypre_set_type value: ams".
> > -Ari
> > To: "petsc-dev" <petsc-dev at mcs.anl.gov>
> > Cc: "Ari Rappaport" <arir at vosssci.com>
> > Sent: Tuesday, August 16, 2016 3:31:16 PM
> > Or - not use '--with-fc=0'. For some reason '-lm' is getting pulled in
> via gfortran - not gcc [on this machine]
> > I've pushed the following fix - to maint/3.7
> > https://bitbucket.org/petsc/petsc/commits/2d90af56370c3153360ed340bfa06d
> 4e662fceff
> > Satish
> > On Tue, 16 Aug 2016, Satish Balay wrote:
> > > /home/mantis/petsc/petsc-3.6.4/linux-gnu/externalpackages/
> hypre-2.10.0b-p4/src/utilities/exchange_data.c:205: undefined reference
> to `ceil'
> > > Try adding configure flag: LIBS=-lm
> > > BTW:
> > > Working directory: /home/mantis/petsc/petsc-3.6.4
> > > Executing: mpicc -show
> > > stdout: gcc -fPIC -g3 -I/home/mantis/petsc/petsc-3.7.2/linux-gnu/include
> -L/home/mantis/petsc/petsc-3.7.2/linux-gnu/lib -Wl,-rpath
> -Wl,/home/mantis/petsc/petsc-3.7.2/linux-gnu/lib -Wl,--enable-new-dtags
> -lmpi
> > > Mixing petsc versions might cause issues..
> > > Satish
> > > On Tue, 16 Aug 2016, Ari Rappaport wrote:
> > > > Hi Barry,
> > > > Sorry for the late reply. Here is my configure.log file. I am
> assuming you meant the configure.log in the petsc-3.6.4 home directory.
> > > > -Ari
> > > > From: "Barry Smith" <bsmith at mcs.anl.gov>
> > > > Cc: "Mark Adams" <mfadams at lbl.gov>, "For users of the development
> version of PETSc" <petsc-dev at mcs.anl.gov>
> > > > Sent: Thursday, August 11, 2016 3:59:47 PM
> > > > > On Aug 11, 2016, at 4:42 PM, Ari Rappaport <arir at vosssci.com>
> wrote:
> > > > > Hi Guys,
> > > > > So the algebraic multigrid works great for a Poisson equation.
> However, it's choking on our Maxwell's Equations solver which is a form of
> curl/curl if I'm not mistaken.
> > > >    Maxwell's equations are tricky for multigrid. hypre has a solver
> specific for Maxwell's equation, you need to check it out; note this is not
> just running with hypre boomerAMG. If you run boomerAMG directly with
> Maxwell's you will not get satisfactory results.
> > > > > I was going to give hypre AMS a try, but I'm having trouble
> installing it. I'm getting the error "Downloaded hypre could not be used".
> > > >   Send configure.log
> > > > > I'm using Ubuntu 14.04 if that makes a difference. Also, is
> non-algebraic multigrid a reasonable choice for Maxwell's Equations?
> > > >    Even with geometric multigrid Maxwell's equations are nontrivial;
> you will need to do some literature search to determine how to handle the
> restriction/interpolation and smoothing to work well for Maxwell.
> > > >    Barry
> > > > > Thanks,
> > > > > Ari
> > > > > Sent: Wednesday, August 10, 2016 2:02:10 PM
> > > > >> On Aug 10, 2016, at 2:52 PM, Ari Rappaport <arir at vosssci.com>
> wrote:
> > > > >> Hi Mark,
> > > > >> There was indeed a bug on our end. Now that we fixed it
> everything is working correctly even in parallel. I have one question still
> though. Is there a way to get the mg_levels_pc_type jacobi option
> > > > >> set in the code without passing it as an argument to
> PetscInitialize? I'm using PCGAMGSetType(pc, PCJACOBI) but it doesn't seem
> to be working.
> > > > >   You can call PetscOptionsSetValue("-<appropriate
> prefix>_mg_levels_pc_type","jacobi") in the code anywhere before your
> code creates the SNES or KSP object you are using. This is equivalent to
> putting it on the command line.
> > > > >  Barry
> > > > >> -Ari
> > > > >> From: "Mark Adams" <mfadams at lbl.gov>
> > > > >> Cc: "For users of the development version of PETSc" <
> > > > >> Sent: Wednesday, July 27, 2016 7:24:24 PM
> > > > >> There is clearly something very wrong with your code. I would
> suggest starting with an example code for instance
> KSP/examples/tutorial/ex56.c and incrementally add your operator to get
> something that is working.
> > > > >> Also if you have multiple degrees of freedom per vertex, for
> instance elasticity, then you want to set the block size of the matrix
> accordingly.
> > > > >> On Wednesday, July 27, 2016, Ari Rappaport < arir at vosssci.com >
> wrote:
> > > > >> Hi Mark,
> > > > >> We added the Jacobi line and it appears to accept that flag now.
> However, we are getting all zeros for the solution vector. And PETSc is
> claiming to have converged in 7 iterations to the relative tolerance.
> > > > >> -Ari
> > > > >> From: "Mark Adams" < mfadams at lbl.gov >
> > > > >> To: "Ari Rappaport" < arir at vosssci.com >, "For users of the
> development version of PETSc" < petsc-dev at mcs.anl.gov >
> > > > >> Sent: Wednesday, July 27, 2016 3:26:03 PM
> > > > >> Please keep this on the Petsc list.
> > > > >> We seem to have lost Jacobi smoother again. I'm suspecting that
> you're some funny character in your line with Jacobi that is Confusing the
> parser. Get back to the old file with the two two Jacobi entries and delete
> the other line and get Jacobi in the KSP view output. There should be no
> SOR in the output.
> wrote:
> > > > >> Hi Mark,
> > > > >> I added all these new things. The PCAMG is now ending very
> quickly but the residual is unreasonably large by about 10 orders of
> magnitude. I noticed the line "Linear solve did not converge due to
> DIVERGED_INDEFINITE_PC iterations 2" in the output, could this be causing
> the problem? It only appears to be going for 2 iterations now.
> > > > >> -Ari
> > > > >> Sent: Tuesday, July 26, 2016 5:07:34 PM
> > > > >> Ari, I would also check that your operator is not messed up in
> parallel. The solver is looking pretty solid.
> > > > >> Also, you can configure PETSc with hypre and use '-pc_type
> hypre'. If hypre is also good in serial but hosed on multi-proc then it is
> most probably your operator.
> > > > >> On Tue, Jul 26, 2016 at 6:58 PM, Mark Adams < mfadams at lbl.gov >
> wrote:
> > > > >> So remove one of the -mg_levels_pc_type jacobi and add
> -mg_coarse_ksp_type preonly, then verify that this works on one proc and
> then try two procs.
> > > > >> On Tue, Jul 26, 2016 at 6:56 PM, Mark Adams < mfadams at lbl.gov >
> wrote:
> > > > >> Oh, actually this worked. You have this ...pc_type jacobi in
> there twice, so one of them was "unused".
> > > > >> Try this with 2 processors now.
> > > > >> On Tue, Jul 26, 2016 at 6:42 PM, Mark Adams < mfadams at lbl.gov >
> wrote:
> > > > >> On Tue, Jul 26, 2016 at 6:24 PM, Ari Rappaport < arir at vosssci.com
> > wrote:
> > > > >> So I commented out the line PCSetType(pc, PCGAMG). The line
> KSPSetFromOptions(ksp) was already in the code at the end of our
> initialization routine. I also added .petscrc to the working dir. Here is
> the current output. It seems as if Option left: name:-mg_levels_pc_type
> jacobi (no value) is still present in the output..I dunno.
> > > > >> Yea, I dunno either. If you use -help you will get printout of
> the available options. If you do this you will see stuff like -mg_levels_1_
> ... you can also see this in the ksp_view. There is a shortcut that lets
> you _not_ put "_1" in. Try putting this in for each level like so:
> > > > >> -mg_levels_1_pc_type jacobi
> > > > >> -mg_levels_2_pc_type jacobi
> > > > >> -mg_levels_3_pc_type jacobi
> > > > >> I also notice that the coarse grid ksp is GMRES. This is our
> fault. It should be preonly. Add:
> > > > >> -Ari
> > > > >> Sent: Tuesday, July 26, 2016 4:03:03 PM
> > > > >> At the end of this you have:
> > > > >> #PETSc Option Table entries:
> > > > >> -ksp_view
> > > > >> -options_left
> > > > >> #End of PETSc Option Table entries
> > > > >> There is one unused database option. It is:
> > > > >> Option left: name:-mg_levels_pc_type jacobi (no value)
> > > > >> So this jacobi parameter is not being used.
> > > > >> Do you call KPSSetFromOptions? Do you set solver parameters in
> the code? Like PCGAMG?
> > > > >> You should not set anything in the code, it just confuses things
> at this point. Use KSPSetFromOptions(). You can hardwire stuff before this
> call, this just lets you set the defaults, but you should always call this
> last to let command line parameters override the defaults.
> > > > >> You can put this in a .petscrc file in the working directory and
> try again.
> > > > >> -ksp_type cg
> > > > >> -ksp_max_it 50
> > > > >> -ksp_rtol 1.e-6
> > > > >> -ksp_converged_reason
> > > > >> -pc_type gamg
> > > > >> -pc_gamg_type agg
> > > > >> -pc_gamg_agg_nsmooths 1
> > > > >> -pc_gamg_coarse_eq_limit 10
> > > > >> -pc_gamg_reuse_interpolation true
> > > > >> -pc_gamg_square_graph 1
> > > > >> -pc_gamg_threshold -0.05
> > > > >> -mg_levels_ksp_max_it 2
> > > > >> -mg_levels_ksp_type chebyshev
> > > > >> -mg_levels_esteig_ksp_type cg
> > > > >> -mg_levels_esteig_ksp_max_it 10
> > > > >> -mg_levels_ksp_chebyshev_esteig 0,.05,0,1.05
> > > > >> -pc_hypre_type boomeramg
> > > > >> -pc_hypre_boomeramg_no_CF
> > > > >> -pc_hypre_boomeramg_agg_nl 1
> > > > >> -pc_hypre_boomeramg_coarsen_type HMIS
> > > > >> -pc_hypre_boomeramg_interp_type ext+i
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160817/472f955d/attachment.html>
