[petsc-dev] FD matrices
Thu Aug 4 19:19:53 CDT 2016
> On Aug 4, 2016, at 10:15 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> Okay, there is
>>  -snes_fd_color -snes_fd_color_use_mat -mat_coloring_type greedy
>> which takes a properly preallocated matrix.
> Which Mat will it use?  Our operators matrix is a shell so it must be the PC ...
   If you are actually going to form the Jacobian and compute it via coloring then there is no particular reason to use a shell matrix as the operator. You might as well just use the Jacobian via coloring that you are computing anyways.
> If it uses the PC Mat we could take the transpose of the PC Mat, scale
> it by like 1.e-30, add it back into the PC Mat to get a symmetric
> structure, if that matters, and get a safe graph for coloring.
   No need to mess with transposes, scales or anything. Just create the matrix (the second one passed to SNESSetJacobian()), do a proper preallocation, put zeros in nonzero locations with MatSetValues, do MatAssembly  and pass it in to SNESSetJacobian()
> Dan: this is easy, I will send you code today to modify "A", just use
> Matt's parameters above.
