[petsc-dev] question about time integrators, TS
Mark Adams mfadams at lbl.gov
Wed Aug 3 14:59:04 CDT 2016
We have a question about the RHS Jacobian (G) for TS.  The manual says:
• Jacobian Gu
If using a fully implicit method and the function G() is provided, one
also can provide an appropriate (approximate) Jacobian matrix of G().
If we use, say, backward Euler and provide a G Jacobian, does PETSc
use this G Jacobian in some way? or is the G Jacobian only used for
IMEX methods?
