[petsc-dev] Make PetscHash publicly accessible
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Fri Apr 22 09:26:41 CDT 2016
> On 22 Apr 2016, at 15:04, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
>> On Fri, Apr 22, 2016 at 4:32 AM, Lawrence Mitchell <
>> lawrence.mitchell at imperial.ac.uk> wrote:
>>> Hi all,
>>> I would like to use the PetscHash functionality in my code.  At the moment
>>> this is not possible, since the header file hash.h is not public (it's in
>>> src/sys/utils/hash.h).  Would there be any objections to moving it to (say)
>>> include/petschash.h so that PETSc applications can use it as well as PETSc
>>> itself.
>> No, go ahead and do it.
> If you do, then you need to namespace everything so it doesn't conflict
> with khash.h from:
Sure.
>  https://github.com/attractivechaos/klib
>  (or https://github.com/clibs/hash)
> Now personally, if I was writing code that was not intended for eventual
> inclusion in PETSc, I would just use upstream khash.h directly.  (PETSc
> should probably upgrade to the latest upstream khash.h.)
That is certainly an option, I was potentially being lazy (oh petsc already has a hash implementation, I'll just use that).  If I'm the only person coding outside of petsc who's ever going to use this, it may not be worth it.
Lawrence
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160422/9967b118/attachment.sig>
