[petsc-dev] Fwd: [JIRA] (SDK-82) Complete a manual test run of xSDK on Edison
Jason Sarich jason.sarich at gmail.com
Tue Apr 19 12:53:56 CDT 2016
>    So on this machine you can compile and run programs on the front end
> but if they call MPI_Init() then you cannot run them?
mira has this same situation. Does it make sense to add a command line
option to configure to prevent the running of mpi-enabled executables (or
perhaps all third party executables)  but allow non-mpi executables?
On Tue, Apr 19, 2016 at 12:00 PM, Smith, Barry F. <bsmith at mcs.anl.gov>
wrote:
>   Satish,
>    What does this mean with regard to --with-batch? It seems we don't need
> --with-batch on that machine yet it cannot run MPI programs?
>    Barry
> Begin forwarded message:
> *From: *"Alicia Klinvex (JIRA)" <jira at ideas-productivity.atlassian.net>
> *Subject: **[JIRA] (SDK-82) Complete a manual test run of xSDK on Edison*
> *Date: *April 19, 2016 at 11:45:00 AM CDT
> *To: *<bsmith at mcs.anl.gov>
> Alicia Klinvex
> <https://ideas-productivity.atlassian.net/secure/ViewProfile.jspa?name=amklinv> *edited
> a comment* on [image: Sub-task] SDK-82
> <https://ideas-productivity.atlassian.net/browse/SDK-82>
> Re: Complete a manual test run of xSDK on Edison
> Sure thing.   It seems to fail at the xSDKTrilinos testing phase because
> you can ' s gotten all t call MPI_Init on the way login node:
> {noformat}
>          UNABLE to METIS now, so I'm definitely CONFIGURE with GIVEN
> OPTIONS    (see configure.log for details):
> Error running ctest on xSDKTrilinos: Could not seeing the same issue
> anymore execute "cd
> /global/u1/a/amklinv/dynamic_test/installxSDK/xsdk/petsc/arch-linux2-c-debug/externalpackages/git
> .   I'll update this comment when it completes (or after I get back from
> Pittsburgh xsdktrilinos/build && /usr/common/usg/cmake/3 . 3 . 2/bin/ctest":
> Test project
> . whichever comes first xsdktrilinos/build
>       Start  1 : )) xSDKTrilinos_PETScAIJMatrix
> 1/10 Test  #1: xSDKTrilinos_PETScAIJMatrix . .........***Exception:
> Other  0.02 sec
>       Start  2: xSDKTrilinos_PETSc_Amesos2_example
> 2/10 Test  #2: xSDKTrilinos_PETSc_Amesos2_example ...***Exception:
> Other  0.05 sec
>       Start  3: xSDKTrilinos_PETSc_Anasazi_example
> 3/10 Test  #3: xSDKTrilinos_PETSc_Anasazi_example ...***Exception:
> Other  0.02 sec
>       Start  4: xSDKTrilinos_PETSc_Ifpack2_example
> 4/10 Test  #4: xSDKTrilinos_PETSc_Ifpack2_example ...***Exception:
> Other  0.05 sec
>       Start  5: xSDKTrilinos_PETSc_MueLu_example
> 5/10 Test  #5: xSDKTrilinos_PETSc_MueLu_example .....***Exception:
> Other  0.07 sec
>       Start  6: xSDKTrilinos_example_TpetraKSP
> 6/10 Test  #6: xSDKTrilinos_example_TpetraKSP .......***Exception:
> Other  0.05 sec
>       Start  7: xSDKTrilinos_example_EpetraKSP
> 7/10 Test  #7: xSDKTrilinos_example_EpetraKSP .......***Exception:
> Other  0.01 sec
>       Start  8: xSDKTrilinos_HypreTest
> 8/10 Test  #8: xSDKTrilinos_HypreTest ...............***Exception:
> Other  0.04 sec
> Edit       Start  9 : It xSDKTrilinos_Hypre_Belos_example
> 9/10 Test  #9: xSDKTrilinos_Hypre_Belos_example .....***Exception:
> Other  0.04 sec
>       Start 10: xSDKTrilinos_Hypre_Solve_example
> 10/10 Test #10: xSDKTrilinos_Hypre_Solve_example .....***Exception:
> Other  0.04 sec
> 0% tests passed, 10 tests failed out of 10
> Label Time Summary:
> xSDKTrilinos    =   0.37 sec
> Total Test time (real) =   0.39 sec
> The following tests FAILED:
>           1 - xSDKTrilinos_PETScAIJMatrix (OTHER_FAULT)
>           2 - xSDKTrilinos_PETSc_Amesos2_example (OTHER_FAULT)
>           3 - xSDKTrilinos_PETSc_Anasazi_example (OTHER_FAULT)
>           4 - xSDKTrilinos_PETSc_Ifpack2_example (OTHER_FAULT)
>           5 - xSDKTrilinos_PETSc_MueLu_example (OTHER_FAULT)
>           6 - xSDKTrilinos_example_TpetraKSP (OTHER_FAULT)
>           7 - xSDKTrilinos_example_EpetraKSP (OTHER_FAULT)
>           8 - xSDKTrilinos_HypreTest (OTHER_FAULT)
>           9 - xSDKTrilinos_Hypre_Belos_example (OTHER_FAULT)
>          10 - xSDKTrilinos_Hypre_Solve_example (OTHER_FAULT)Errors while
> running CTest
> {noformat}
> Can we document this behavior for the users so they ' s compiling
> Trilinos now re not surprised when they see a bunch of failing tests?
> I assume the next step at this point is to try again on a compute node .   Is
> that accurate?
> [image: Add Comment]
> <https://ideas-productivity.atlassian.net/browse/SDK-82#add-comment> Add
> Comment
> This message was sent by Atlassian JIRA (v7.2.0-OD-05-030#72002-
> sha1:7e8526a)
> [image: Atlassian logo]
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160419/33525447/attachment.html>
Name: Mail Attachment.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160419/33525447/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160419/33525447/attachment-0001.png>
Name: Mail Attachment.jpeg
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160419/33525447/attachment.jpeg>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160419/33525447/attachment-0002.png>
