[petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2016-04-08
Tobin Isaac tisaac at uchicago.edu
Fri Apr 8 14:36:04 CDT 2016
I spent a couple minutes verifying that there is no code path where
that variable is not initialized on line 3437.
-Wmaybe-uninitialized seems to generate a lot of false positives.
Coupled with the blame digest's poor ability to assign blame, this
proactive approach seems to waste more time than a reactive
SEGV->valgrind->fix approach.
Cheers,
  Toby
On Fri, Apr 08, 2016 at 02:12:22PM -0500, Satish Balay wrote:
> This should have been sent to Toby.
> I don't really understand the issue here. Its triggered by --with-debugging=0. I'm
> not sure why these compilers are pointing to petscsys.h. I get slightly different message
> on my laptop.
> mpicc -c -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g -O   -I/home/balay/petsc/include -I/home/balay/petsc/arch-linux2-c-opt/include -I/home/balay/soft/mpich-3.1.4/include    -MMD -MP /home/balay/petsc/src/dm/impls/plex/plextree.c -o arch-linux2-c-opt/obj/src/dm/impls/plex/plextree.o
> /home/balay/petsc/src/dm/impls/plex/plextree.c: In function ‘DMPlexComputeInjectorTree’:
> /home/balay/petsc/src/dm/impls/plex/plextree.c:3484:11: warning: ‘childrenMats’ may be used uninitialized in this function [-Wmaybe-uninitialized]
>    ierr = PetscFree(refPointFieldMats);CHKERRQ(ierr);
> /home/balay/petsc/src/dm/impls/plex/plextree.c:3507:18: note: ‘childrenMats’ was declared here
>    PetscScalar    ***childrenMats;
> Satish
> On Fri, 8 Apr 2016, PETSc checkBuilds wrote:
> > Dear PETSc developer,
> > This email contains listings of contributions attributed to you by
> > `git blame` that caused compiler errors or warnings in PETSc automated
> > testing.  Follow the links to see the full log files. Please attempt to fix
> > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> > to resolve the issues.
> > Thanks,
> >   The PETSc development team
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/49d7da5
> > PetscMalloc: allow ptr=malloc(0) and free(ptr)
> >   include/petscsys.h:1157
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
> >       /usr/home/balay/petsc.clone-2/include/petscsys.h:1157:88: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-opt-cxx-quad_grind.log]
> >       /sandbox/petsc/petsc.clone-3/include/petscsys.h:1157:88: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-freebsd-pkgs-opt_wii.log]
> >       /usr/home/balay/petsc.clone/include/petscsys.h:1157:39: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-pkgs-latest_cg.log]
> >       /sandbox/petsc/petsc.clone-4/include/petscsys.h:1157:25: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-pkgs-opt_crank.log]
> >       /sandbox/petsc/petsc.clone/include/petscsys.h:1157:25: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
> > To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160408/cb1ac17a/attachment.sig>
