[petsc-dev] PETSc blame digest (next) 2016-04-08
Michael Lange michael.lange at imperial.ac.uk
Fri Apr 8 09:42:41 CDT 2016
Hi Matt,
I just pushed the branch mlange/fix-plex-fluent-reader that re-enables
the plex-fluent test cases and hopefully fixes these warnings. Can you
please double-check this and merge to next/master?
Michael
On 08/04/16 15:00, PETSc checkBuilds wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
>    The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/3f6dc66
> Plex-Fluent: Add coordinates to the generated Plex
>    src/dm/impls/plex/plexfluent.c:408
>      [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_arch-linux-analyzer_crush.log]
>        /sandbox/petsc/petsc.clone/src/dm/impls/plex/plexfluent.c:408:27: warning: Array access (from variable 'coordsIn') results in a null pointer dereference
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/f732056
> Plex-Fluent: Build Plex topology from face connectivity
>    src/dm/impls/plex/plexfluent.c:322
>        /sandbox/petsc/petsc.clone/src/dm/impls/plex/plexfluent.c:322:27: warning: Array access (from variable 'faces') results in a null pointer dereference
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
