[petsc-dev] Correct syntax for DMDA ownership ranges in petsc4py
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Fri Apr 8 08:46:12 CDT 2016
> On 8 Apr 2016, at 14:35, Chris Eldred <chris.eldred at gmail.com> wrote:
> Great! How would I go about testing that change- I have been using the
> petsc4py version that comes with Firedrake, so what is the correct way
> to modify petsc4py and rebuild it?
Just modify the file in the repo and pip install from that directory again.
cd path/to/petsc4py_dir
pip install --upgrade .
Lawrence
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160408/bd2ea9ba/attachment.sig>
