[petsc-dev] technical C question
Jed Brown jed at jedbrown.org
Thu Apr 7 14:37:16 CDT 2016
Barry Smith <bsmith at mcs.anl.gov> writes:
> the clang static code analyzer reports
> In file included from /sandbox/petsc/petsc.clone/include/petsc/private/matimpl.h:1233:
> /sandbox/petsc/petsc.clone/include/petscbt.h:85:36: warning: The result of the '<<' expression is undefined
>           BT_mask       = (char)(1 << index%PETSC_BITS_PER_BYTE),
> Is the code wrong/unnecessary or clang?
I would guess it is complaining about C99 §6.5.7.3:
  If the value of the right operand is negative or is greater than or
  equal to the width of the promoted left operand, the behavior is
  undefined.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160407/bf9d68d9/attachment.sig>
