[petsc-dev] freebsd breakage
Tobin Isaac
tisaac at ices.utexas.edu
Tue Sep 8 11:29:47 CDT 2015
Right, working on it.
Toby
On Tue, Sep 08, 2015 at 11:28:16AM -0500, Barry Smith wrote:
> Toby,
> This must be your pull request causing grief.
> Barry
> > On Sep 8, 2015, at 11:23 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/configure_next_arch-freebsd-cxx-pkgs-opt_wii.log
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/08/configure_next_arch-freebsd-pkgs-opt_wii.log
> > https://bitbucket.org/petsc/petsc/commits/e1450d8053bc869c6cfb945a2ea6dba10cadf607 is triggering this.
> > sept-3: ================================================================================
> > TEST checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1246)
> > TESTING: checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1246)
> > Check that the linker can produce shared libraries
> > Executing: uname -s
> > stdout: FreeBSD
> > Checking shared linker /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx using flags ['-shared']
> > Checking for program /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx...found
> > Defined make macro "LD_SHARED" to "/usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx"
> > Executing: /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicc -c -o /tmp/petsc-GagEyB/config.setCompilers/conftest.o -I/tmp/petsc-GagEyB/config.compilers -I/tmp/petsc-GagEyB/config.utilities.closure -I/tmp/petsc-GagEyB/config.headers -I/tmp/petsc-GagEyB/config.utilities.cacheDetails -I/tmp/petsc-GagEyB/config.types -I/tmp/petsc-GagEyB/config.atomics -I/tmp/petsc-GagEyB/config.utilities.getResidentSetSize -I/tmp/petsc-GagEyB/config.libraries -I/tmp/petsc-GagEyB/config.utilities.featureTestMacros -I/tmp/petsc-GagEyB/config.utilities.missing -I/tmp/petsc-GagEyB/config.setCompilers -I/tmp/petsc-GagEyB/config.functions -fPIC /tmp/petsc-GagEyB/config.setCompilers/conftest.c
> > Successful compile:
> > sept-8: ================================================================================
> > TEST checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1263)
> > TESTING: checkSharedLinker from config.setCompilers(/usr/home/balay/petsc.clone-2/config/BuildSystem/config/setCompilers.py:1263)
> > Executing: uname -s
> > stdout: FreeBSD
> > Executing: /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicc -c -o /tmp/petsc-xTFsod/config.setCompilers/conftest.o -I/tmp/petsc-xTFsod/config.compilers -I/tmp/petsc-xTFsod/config.utilities.closure -I/tmp/petsc-xTFsod/config.headers -I/tmp/petsc-xTFsod/config.utilities.cacheDetails -I/tmp/petsc-xTFsod/config.types -I/tmp/petsc-xTFsod/config.atomics -I/tmp/petsc-xTFsod/config.utilities.getResidentSetSize -I/tmp/petsc-xTFsod/config.libraries -I/tmp/petsc-xTFsod/config.utilities.featureTestMacros -I/tmp/petsc-xTFsod/config.utilities.missing -I/tmp/petsc-xTFsod/config.setCompilers -I/tmp/petsc-xTFsod/config.functions /tmp/petsc-xTFsod/config.setCompilers/conftest.c
> > Successful compile:
> > So the -fPIC is missing from the sep-8 compile - triggering this issue?
> > Satish
Desc: Digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150908/cb9b1312/attachment.sig>
