[petsc-dev] [SLEPc] For users of PETSc master branch, API change
Leoni, Massimiliano Massimiliano.Leoni at Rolls-Royce.com
Mon Nov 9 09:25:43 CST 2015
Satish,
Yes, I was already doing that, just preferred to check.
Jose,
Thanks, I will upgrade tomorrow.
Best,
Massimiliano
> -----Original Message-----
> From: Jose E. Roman [mailto:jroman at dsic.upv.es]
> Sent: 09 November 2015 14:48
> To: petsc-users
> Cc: Leoni, Massimiliano; petsc-dev
> Subject: Re: [petsc-dev] [SLEPc] For users of PETSc master branch, API
> change
> The fix is already in SLEPc's branches 'jose/sync-with-petsc' and 'next'.
> Will merge into 'master' tomorrow.
> Jose
> > El 9/11/2015, a las 15:44, Satish Balay <balay at mcs.anl.gov> escribió:
> > you can try using a slightly older 'master' snapshot' [until you get
> > the slpec fix]
> > For eg:
> > git checkout d916695f21d798ebdf80dc439ef54c5223c9183c
> > And once the slepc fix is available - you can do:
> > git checkout master
> > git pull
> > Satish
> > On Mon, 9 Nov 2015, Leoni, Massimiliano wrote:
> >> Ok, sorry!
> >> It looks like I chose the worst possible day to update :D
> >> Best,
> >> Massimiliano
> >>> Sent: 09 November 2015 14:26
> >>> To: Leoni, Massimiliano
> >>> Cc: Barry Smith; PETSc; petsc-dev
> >>> API change
> >>> Working on it. Be patient. Should be available on master tomorrow.
> >>> Jose
> >>>> El 9/11/2015, a las 15:23, Leoni, Massimiliano
> >>>> <Massimiliano.Leoni at Rolls-
> >>> Royce.com> escribió:
> >>>> Is there a branch in the SLEPc repo that supports this?
> >>>> Massimiliano
> >>>>> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-
> >>>>> bounces at mcs.anl.gov] On Behalf Of Barry Smith
> >>>>> Sent: 09 November 2015 00:21
> >>>>> To: PETSc; petsc-dev
> >>>>> Subject: [petsc-dev] For users of PETSc master branch, API change
> >>>>>  For users of the PETSc master branch.
> >>>>>  I have pushed into master some API changes for the
> >>>>> PetscOptionsGetXXX() and related routines. The first argument is
> >>>>> now a PetscOptions object, which is optional, if you pass a NULL
> >>>>> in for the first argument (or a PETSC_NULL_OBJECT in Fortran) you
> >>>>> will retain the same functionality as you had previously.
> >>>>>  Barry
> >>>> The data contained in, or attached to, this e-mail, may contain
> >>>> confidential
> >>> information. If you have received it in error you should notify the
> >>> sender immediately by reply e-mail, delete the message from your
> >>> system and contact +44 (0) 3301235850 (Security Operations Centre)
> >>> if you need assistance. Please do not copy it for any purpose, or
> >>> disclose its contents to any other person.
> >>>> An e-mail response to this address may be subject to interception
> >>>> or
> >>> monitoring for operational reasons or for lawful business practices.
> >>>> (c) 2015 Rolls-Royce plc
> >>>> Registered office: 62 Buckingham Gate, London SW1E 6AT Company
> >>> number: 1003142. Registered in England.
> >> The data contained in, or attached to, this e-mail, may contain confidential
> information. If you have received it in error you should notify the sender
> immediately by reply e-mail, delete the message from your system and
> contact +44 (0) 3301235850 (Security Operations Centre) if you need
> assistance. Please do not copy it for any purpose, or disclose its contents to
> any other person.
> >> An e-mail response to this address may be subject to interception or
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 3301235850 (Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
