[petsc-dev] Compile error
Leoni, Massimiliano Massimiliano.Leoni at Rolls-Royce.com
Mon Nov 9 07:58:22 CST 2015
Matt, Jose,
Thank you for the advice, it worked of course :)
Best,
Massimiliano
> -----Original Message-----
> From: Jose E. Roman [mailto:jroman at dsic.upv.es]
> Sent: 09 November 2015 12:19
> To: Leoni, Massimiliano
> Cc: petsc-dev at mcs.anl.gov; petsc-maint at mcs.anl.gov
> Subject: Re: [petsc-dev] Compile error
> > El 9/11/2015, a las 13:14, Leoni, Massimiliano <Massimiliano.Leoni at Rolls-
> Royce.com> escribió:
> > Hi, I recently pulled the latest commits and tried to recompile, but an error
> occurred.
> > I attach the log files.
> > Thanks,
> > Massimiliano
> > The data contained in, or attached to, this e-mail, may contain confidential
> information. If you have received it in error you should notify the sender
> immediately by reply e-mail, delete the message from your system and
> contact +44 (0) 3301235850 (Security Operations Centre) if you need
> assistance. Please do not copy it for any purpose, or disclose its contents to
> any other person.
> > An e-mail response to this address may be subject to interception or
> monitoring for operational reasons or for lawful business practices.
> > (c) 2015 Rolls-Royce plc
> > Registered office: 62 Buckingham Gate, London SW1E 6AT Company
> number: 1003142. Registered in England.
> > <configure.log><make.log>
> Delete $PETSC_ARCH directory and reconfigure.
> Jose
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 3301235850 (Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
