[petsc-dev] For users of PETSc master branch, API change
Sun Nov 8 18:20:50 CST 2015
   For users of the PETSc master branch.
   I have pushed into master some API changes for the PetscOptionsGetXXX() and related routines. The first argument is now a PetscOptions object, which is optional, if you pass a NULL in for the first argument (or a PETSC_NULL_OBJECT in Fortran) you will retain the same functionality as you had previously.
   Barry
