[petsc-dev] memory leak
Sun May 31 21:24:06 CDT 2015
  Thanks. This is our bug, the custom Fortran stub did not free the array of subksp.
   I have fixed in master and next
  Barry
> On May 31, 2015, at 9:02 PM, Mark Adams <mfadams at lbl.gov> wrote:
> This is coming from this line (last):
> #undef __FUNCT__
> #define __FUNCT__ "PCFieldSplitGetSubKSP_FieldSplit_Schur"
> static PetscErrorCode  PCFieldSplitGetSubKSP_FieldSplit_Schur(PC pc,PetscInt *n,KSP **subksp)
>   PC_FieldSplit  *jac = (PC_FieldSplit*)pc->data;
>   PetscErrorCode ierr;
>   PetscFunctionBegin;
>   ierr = PetscMalloc1(jac->nsplits,subksp);CHKERRQ(ierr);
> I call it with:
>   KSP::subksp(2)
>   call PCFieldSplitGetSubKSP(solver%pc,PETSC_NULL_INTEGER,subksp,ierr)
> The Fortran wrapper is:
> PETSC_EXTERN void PETSC_STDCALL pcfieldsplitgetsubksp_(PC *pc,PetscInt *n_local,KSP *ksp,PetscErrorCode *ierr)
>   KSP      *tksp;
>   PetscInt i,nloc;
>   CHKFORTRANNULLINTEGER(n_local);
>   *ierr = PCFieldSplitGetSubKSP(*pc,&nloc,&tksp); if (*ierr) return;
>   if (n_local) *n_local = nloc;
>   CHKFORTRANNULLOBJECT(ksp);
>   if (ksp) {
>     for (i=0; i<nloc; i++) ksp[i] = tksp[i];
> Should I just add a PetscFree(&tksp) here?
> On Sun, May 31, 2015 at 7:24 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Sat, May 30, 2015 at 10:51 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Need more details. How can we reproduce this?
> I was hoping this would be obvious. a missed free.
> What tests use Schur solvers?  I could see if they have the same problem.
>   Barry
> > On May 30, 2015, at 7:10 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > This look like there might be a memory leak in PETSc.  Let me know if this is not obvious and get more detail.
> > Mark
> > [0]Total space allocated 16 bytes
> > [ 0]16 bytes PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in /global/u2/m/madams/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> >       [0]  PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in /global/u2/m/madams/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> >       [0]  PCFieldSplitGetSubKSP() line 1665 in /global/u2/m/madams/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> >       [0]  KSPSetUp() line 247 in /global/u2/m/madams/petsc/src/ksp/ksp/interface/itfunc.c
