[petsc-dev] memory leak
Mark Adams mfadams at lbl.gov
Sun May 31 21:02:52 CDT 2015
This is coming from this line (last):
#undef __FUNCT__
#define __FUNCT__ "PCFieldSplitGetSubKSP_FieldSplit_Schur"
static PetscErrorCode  PCFieldSplitGetSubKSP_FieldSplit_Schur(PC
pc,PetscInt *n,KSP **subksp)
  PC_FieldSplit  *jac = (PC_FieldSplit*)pc->data;
  PetscErrorCode ierr;
  PetscFunctionBegin;
  ierr = PetscMalloc1(jac->nsplits,subksp);CHKERRQ(ierr);
I call it with:
  KSP::subksp(2)
  call PCFieldSplitGetSubKSP(solver%pc,PETSC_NULL_INTEGER,subksp,ierr)
The Fortran wrapper is:
PETSC_EXTERN void PETSC_STDCALL pcfieldsplitgetsubksp_(PC *pc,PetscInt
*n_local,KSP *ksp,PetscErrorCode *ierr)
  KSP      *tksp;
  PetscInt i,nloc;
  CHKFORTRANNULLINTEGER(n_local);
  *ierr = PCFieldSplitGetSubKSP(*pc,&nloc,&tksp); if (*ierr) return;
  if (n_local) *n_local = nloc;
  CHKFORTRANNULLOBJECT(ksp);
  if (ksp) {
    for (i=0; i<nloc; i++) ksp[i] = tksp[i];
Should I just add a PetscFree(&tksp) here?
On Sun, May 31, 2015 at 7:24 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Sat, May 30, 2015 at 10:51 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Need more details. How can we reproduce this?
> I was hoping this would be obvious. a missed free.
> What tests use Schur solvers?  I could see if they have the same problem.
>>   Barry
>> > On May 30, 2015, at 7:10 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > This look like there might be a memory leak in PETSc.  Let me know if
>> this is not obvious and get more detail.
>> > Mark
>> > [0]Total space allocated 16 bytes
>> > [ 0]16 bytes PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in
>> /global/u2/m/madams/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>> >       [0]  PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in
>> >       [0]  PCFieldSplitGetSubKSP() line 1665 in
>> >       [0]  KSPSetUp() line 247 in
>> /global/u2/m/madams/petsc/src/ksp/ksp/interface/itfunc.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150531/6a5fef12/attachment.html>
