[petsc-dev] new P^1.5 algorithm in VecAssembleBegin?
Jed Brown jed at jedbrown.org
Fri May 29 14:29:35 CDT 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
>   I cannot explain why the load balance would be 1.0 unless, by
>   unlikely coincidence on the 248 different calls to the function
>   different processes are the ones waiting so that the sum of the
>   waits on different processes matches over the 248 calls. Possible
>   but
Uh, it's the same reason VecNorm often shows significant load imbalance.
>> I've added a barrier in the code.
>    You don't need a barrier.  If you do not have a barrier you should
>    see all the "wait time" now accumulate somewhere later in the code
>    at the next reduction after the VecAssemblyBegin/End.
Presumably he added a barrier *before* calling the function.  The
function does a small amount of work (basically none because he has no
off-process entries) and synchronizes (PetscMaxSum).  If there was load
imbalance before calling VecAssemblyBegin, the timer would start at
different times on each process, but end at about the same time.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150529/b659dda5/attachment.sig>
