[petsc-dev] new P^1.5 algorithm in VecAssembleBegin?
Thu May 28 18:48:22 CDT 2015
   VecAssemblyBegin() serves as a barrier unless you set the vector option VEC_IGNORE_OFF_PROC_ENTRIES so I am not surprised that it "appears" to take a lot of time. BUT the balance between the fastest and slowest is listed in your table below is 1.0  which is very surprising; indicating every process supposedly spent the same amount of time within the VecAssemblyBegin(). Note that for VecAssemblyEnd() the balance is 2.3 which is what I commonly would expect. Please send me ALL the output for -log_summary for these cases.  Version of PETSc shouldn't matter for this issue.
> On May 28, 2015, at 4:59 PM, Mark Adams <mfadams at lbl.gov> wrote:
> We are seeing some large times spent in VecAssemblyBegin:
> VecAssemblyBegin     242 1.0 7.9796e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 7.3e+02 12  0  0  0  5  76  0  0  0 10     0
> VecAssemblyEnd       242 1.0 5.6624e-04 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> This is with 64K cores on Edison.  On 128K cores (weak speedup) we see:
> VecAssemblyBegin     248 1.0 2.3615e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 7.4e+02 17  0  0  0  4  87  0  0  0 10     0
> VecAssemblyEnd       248 1.0 6.8855e-04 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
> We are working on using older versions of PETSc to make sure this is a PETSc issue but does anyone have any thoughts on this?
> Mark
