[petsc-dev] Fwd: [petsc-users] configure error on Titan with Intel
Thu May 14 17:24:24 CDT 2015
Ok. If using --with-cxxlib-autodetect=0 with LIBS - you could try:
LIBS='-lzceh -lgcc_eh -lstdz -lCz'
Satish
On Thu, 14 May 2015, Mark Adams wrote:
> I've commented the autodect lines out and am waiting for a compute node.
> Here is what you wanted.
> Thanks,
> On Thu, May 14, 2015 at 11:27 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > You mention multiple failures here - but include log for only one case.
> > Ideally lanugage compilers (c,c++,fortran) should interoperate with
> > each other - but without it - one has to know the 'compatibility
> > libraries' to use.
> > -lstdc++ is a gnu/c++ library. For PGI - the library names could be
> >  diffferent.
> > --with-cxxlib-autodetect=1 - which is configure default - tries to
> > determine this list - but with cray modules - this causes multiple
> > listing of all libraries that are setup via modules - sometimes
> > causing grief - hence you are using --with-cxxlib-autodetect=0 on cray
> > builds.
> > Can you send me the following info?
> > cd src/benchmarks
> > cc -v sizeof.c
> > CC -v sizeof.c
> > Also you can try --with-cxxlib-autodetect=1 - and see if it works.
> > Satish
> > > We have Titan working but we have a problem that we need lstdc++ to get
> > > PETSc to configure.  Otherwise it fails to build fortran.  This seems to
> > > only be needed for GNU.  This is for PGI.  If we remove this C++ works,
> > > otherwise there is a missing external.  I guess I can just deploy two
> > > version, on for fortran and one for C++ (I have a C++ and a fortran code
> > > that I support).
> > > On Tue, May 12, 2015 at 9:36 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > >   Remind me again how much the US tax payers spend on this machine each
> > > > year.
> > > > Begin forwarded message:
> > > > *From: *Mark Adams <mfadams at lbl.gov>
> > > > *Subject: **Re: [petsc-users] configure error on Titan with Intel*
> > > > *Date: *May 12, 2015 at 11:12:55 AM CDT
> > > > *To: *Barry Smith <bsmith at mcs.anl.gov>
> > > > *Cc: *Jed Brown <jed at jedbrown.org>, petsc-users <
> > petsc-users at mcs.anl.gov>,
> > > > "David Trebotich" <treb at lbl.gov>, "D'Azevedo, Ed F." <
> > dazevedoef at ornl.gov>
> > > >>   Notes: ./configure ran fine and detected -lhwloc in some standard
> > > >> system install location under normal circumstances it couldn't just
> > > >> disappear for a different example.
> > > > I configured in an interactive shell, so on a compute node.  I tried to
> > > > 'make ex56' on a login node, as usual.  So I am guessing that it would
> > have
> > > > worked if I had made it a compute node.  They have an inconstancy, I'm
> > > > guessing. I can try it all on a compute node ....
> > > > Mark
> > > >> > On Fri, May 8, 2015 at 5:51 PM, Jed Brown <jed at jedbrown.org> wrote:
> > > >> > Satish Balay <balay at mcs.anl.gov> writes:
> > > >> > > Also - Perhaps with intel compilers - the recommended blas is
> > > >> > > something other than ACML? [like MKL?]. Something to check..
> > > >> > MKL (and anything built using the Intel compiler) has the "run
> > slower on
> > > >> > AMD" feature.  For any given operation, ACML won't necessarily be
> > > >> > faster, but at least it's not intentionally crippled.  For most of
> > what
> > > >> > PETSc does, any such MKL/ACML difference is irrelevant.
> > > >> > <configure.log><make.log>
