[petsc-dev] Bug in MatGetSubMatrix_SeqBAIJ
Stefano Zampini stefano.zampini at gmail.com
Sun May 10 12:27:42 CDT 2015
I created a pull request
https://bitbucket.org/petsc/petsc/pull-request/316/matseqbaij-fix-for-matgetsubmatrix_seqbaij/diff
Stefano
Il 10/mag/2015 07:48 PM, "Barry Smith" <bsmith at mcs.anl.gov> ha scritto:
>   Stefano,
>    Better to make these reports a pull request even if you plan to merge
> it yourself rather than emailing a branch name; makes it easier for
> everyone else to track and see what you have done.
>    If you intend the fix to go into maint you need to make the branch off
> of maint (not master) and then make the pull request off of maint.
>   "is buggy" is also a bit vague a term. It would be better to explain at
> a high level what the bug was, looks like confusion between rows and column
> sizes or something.
>   Barry
> > On May 10, 2015, at 6:51 AM, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
> > The current code for MatGetSubMatrix_SeqBAIJ is buggy. I pushed a fix in
> stefano_zampini/matbaij-fixgetsubmatrix. If it is ok with you, than I'll
> merge to master (and maint?).
> > Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150510/2235399c/attachment.html>
