[petsc-dev] handling user domain errors
Mon May 4 20:15:17 CDT 2015
On Mon, May 4, 2015 at 6:20 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   My first reaction to this was "man that is ugly and cumbersome, I can do
> it much cleaner than that"; turns out it isn't as simple as I thought but
> with a couple of macros I think I've incorporated much of what is needed in
> https://bitbucket.org/petsc/petsc/pull-request/315/propagating-solver-errors-instead-of/diff
> some work needs to be done on getting the most appropriate SNES converged
> reason set. In fact one could argue that trying to pass the converged
> reason up as a single enum type may not be the best model since there may
> be more information that one wishes to convey such as function domain error
> that happened while differencing the function with coloring to compute the
> Jacobian.
>   Anyways in particular look at the test example ex69.c
I like this idea that we switch interpretation of some conditions from
error to snafu. This is exactly what Patrick was asking
for in SNESComposite and I think its what most people want.
  Matt
>   Barry
> > On May 1, 2015, at 10:52 PM, Dmitry Karpeyev <dkarpeev at gmail.com> wrote:
> > Here's the first crack at it:
> https://bitbucket.org/petsc/petsc/branch/karpeev/ksp-diverged-on-matmult-nanorinf
> > Messier than I had expected (GMRES only for now).
> > On Fri, May 1, 2015 at 8:06 PM Dmitry Karpeyev <dkarpeev at gmail.com>
> wrote:
> > On Fri, May 1, 2015 at 7:32 PM Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On May 1, 2015, at 6:43 PM, Jed Brown <jed at jedbrown.org> wrote:
> > > Barry Smith <bsmith at mcs.anl.gov> writes:
> > >>   1) This simplifies the needed code since we won't need to put
> > >>   checks all over the place on returns about failure nor do we need
> > >>   to worry about propagating errors from one process to another
> > >>   (since the Nan/Inf get moved by the MPI_Allreduce()).
> > > My concern is that -fp_trap will become a lot less useful.
> >   I agree there is a tradeoff; but under "normal" circumstances where
> there are no Nan or Inf around (which I think is most of the time) -fp_trap
> will be just as useful as now. For the other cases the user will have to
> have some idea where (and when) in the code to turn on the trapping to
> catch the "true" problems.
> >    Barry
> >   The only other way I see to do it is carry a validity flag around with
> each vector and reduce that flag in all the vector reductions; but this
> alone is not enough we would also have to have some propagation code for
> things like zero pivot, for example setting a validity flag in the Mat
> factor (saying the factor is not valid) and propagating up those flags. We
> get all these things "for free" with the Inf Nan approach.
> > There is an additional benefit: the validity flag would have to be
> cleared by the caller to avoid "false positives" on subsequent calls.
> That's an opportunity for bugs.  With NaN the "error condition" (i.e., the
> NaN entry) gets cleared automatically by a subsequent successful vector
> operation.
> > What exactly caused the NaN would have to be signaled "out-of-band" as
> the saying goes. One way to "signal" it is by the code path that led to the
> error condition: that's why calling through KSP_MatMult() is useful.  It's
> not ideal, but covers the cases of immediate interest.
> > Dmitry.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150504/28b71808/attachment.html>
