[petsc-dev] MatCreateVecs interface
Thu Jun 25 12:38:46 CDT 2015
On Thu, Jun 25, 2015 at 12:32 PM, Stefano Zampini <stefano.zampini at gmail.com
> wrote:
> pushed a fix
> https://bitbucket.org/petsc/petsc/commits/ae287a2e7a141494f7c41f9dd537addb63b556e3
> However, it appears that the functions below for CUSP, CUSPARSE and
> VIENNACL are mere copies of the interface.
> What  about defining the type of the Vec in the interface and get rid of
> these?
I think the point here is that the matrix should return Vecs of a
compatible type, not a user specified one.
  Matt
> src/mat/impls/aij/mpi/mpicusp/mpiaijcusp.cu:  A->ops->getvecs        =
> MatCreateVecs_MPIAIJCUSP;
> src/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.cu:  A->ops->getvecs
>     = MatCreateVecs_MPIAIJCUSPARSE;
> src/mat/impls/aij/mpi/mpiviennacl/mpiaijviennacl.cxx:  A->ops->getvecs
>     = MatCreateVecs_MPIAIJViennaCL;
> src/mat/impls/aij/seq/seqcusp/aijcusp.cu:  B->ops->getvecs        =
> MatCreateVecs_SeqAIJCUSP;
> src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu:  B->ops->getvecs
>   = MatCreateVecs_SeqAIJCUSPARSE;
> src/mat/impls/aij/seq/seqviennacl/aijviennacl.cxx:  B->ops->getvecs
> = MatCreateVecs_SeqAIJViennaCL;
> Stefano
> On Jun 25, 2015, at 4:34 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  I think you are right, go ahead and make a pull request or send a patch
>  Barry
> On Jun 25, 2015, at 9:43 AM, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
> Why the current interface in MatCreateVecs requires that a matrix has been
> already either allocated or setup ?
> Shouldn’t be enough to check if the layout has been already setup?
> Stefano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150625/bac9a5e6/attachment.html>
