[petsc-dev] Error when calling PETSc
Mon Jun 22 19:38:50 CDT 2015
  You are missing the ierr argument
> On Jun 22, 2015, at 7:33 PM, Hector E Barrios Molano <hectorb at utexas.edu> wrote:
> Hi Satish,
> I run this program with petsc-master on Linux with Valgrind and idb.
> Here is how I am calling PETSc:
>          call MatCreateBAIJ(MPI_COMM_WORLD,nblock/2,N_mat,N_mat,
>>        PETSC_DECIDE,PETSC_DECIDE,PETSC_DEFAULT_INTEGER,PNNZD,
>>        PETSC_DEFAULT_INTEGER,PNNZO,mat,ierr)
>          call MatSetup(mat,ierr)
>          call MatSetOption(mat, MAT_NEW_NONZERO_ALLOCATION_ERR,
>>        PETSC_FALSE)
> Any idea of this error?, both idb and valgrind points to matrixf.c:890
> Thanks,
> Here is idb output:
> matsetoption_ (mat=0x36e1e48, op=0x32c2a20, flg=0x32c296c,
> __ierr=0x32c296c) at
> /home/hector/dwnld_prog/petsc-master/src/mat/interface/ftn-auto/matrixf.c:890
> 890    *__ierr = MatSetOption(
> And this is the valgrind output:
> $ valgrind --track-origins=yes --leak-check=full ./prog -d 3comp.dat
> ==18555== Memcheck, a memory error detector
> ==18555== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al.
> ==18555== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright info
> ==18555== Command: ./prog -d 3comp.dat
> ==18555==
> ==18555== Warning: set address range perms: large range [0x36fc000,
> 0x2e2b7000) (defined)
> NUMPRC:            1
>  PSTD, TRSTD =    14.6960000000000        519.670000000000       in INFLUID
>       TIME         TIMESTEP    ITERATION   FLASH_RES     VOLUME_RES
>    MASS_RES      WATER_RES
> going into SOLVERS
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.6-34-gc9ff9ea  GIT
> Date: 2015-06-17 23:52:21 -0500
> [0]PETSC ERROR: ./prog on a linux-intel named petros.cpge.utexas.edu
> by hector Mon Jun 22 19:25:59 2015
> [0]PETSC ERROR: Configure options
> --prefix=/home/hector/installed/petsc3.6-intel
> --PETSC_ARCH=linux-intel
> --with-mpi-dir=/home/hector/installed/openmpi-intel/
> --with-parmetis-dir=/home/hector/installed/parmetis/
> --with-metis-dir=/home/hector/installed/parmetis/
> --with-zoltan-dir=/home/hector/installed/zoltan/ --download-ptscotch
> --download-hypre
> --with-blas-lapack-dir=/share/apps/intel/composer_xe_2011_sp1.9.293/mkl/
> --with-valgrind=1 --with-valgrind-dir=/home/hector/installed
> --with-shared-libraries=0
> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> ==18555==
> ==18555== HEAP SUMMARY:
> ==18555==     in use at exit: 52,616,185 bytes in 7,935 blocks
> ==18555==   total heap usage: 121,248 allocs, 113,313 frees,
> 69,099,609 bytes allocated
> ==18555==
> ==18555== 240 bytes in 6 blocks are definitely lost in loss record
> 5,950 of 6,383
> ==18555==    at 0x2ECBEAF0: malloc (vg_replace_malloc.c:296)
> ==18555==    by 0x324D4798E1: strdup (in /lib64/libc-2.5.so)
> ==18555==    by 0x331E1A27: opal_show_help_vstring (in
> /home/hector/installed/openmpi-intel/lib/libopen-pal.so.6.2.1)
> ==18555==    by 0x32F30F53: orte_show_help (in
> /home/hector/installed/openmpi-intel/lib/libopen-rte.so.7.0.5)
> ==18555==    by 0x32A5F709: PMPI_Abort (in
> /home/hector/installed/openmpi-intel/lib/libmpi.so.1.6.1)
> ==18555==    by 0x245A9F3: PetscSignalHandlerDefault (signal.c:161)
> ==18555==    by 0x245A356: PetscSignalHandler_Private (signal.c:49)
> ==18555==    by 0x324D4302EF: ??? (in /lib64/libc-2.5.so)
> ==18555==    by 0x20A104E: matsetoption_ (matrixf.c:890)
> ==18555==    by 0x1BE0576: jpetsc3d_ (xsolver.f:382)
> ==18555==    by 0x1BDC9A3: xsolver_ (xsolver.f:104)
> ==18555==    by 0x1AB1BB3: solvers_ (xsolve.f:60)
> ==18555==
> ==18555== 336 bytes in 1 blocks are possibly lost in loss record 6,043 of 6,383
> ==18555==    at 0x2ECC0867: calloc (vg_replace_malloc.c:623)
> ==18555==    by 0x324D0100A2: _dl_allocate_tls (in /lib64/ld-2.5.so)
> ==18555==    by 0x324E006EB8: pthread_create@@GLIBC_2.2.5 (in
> /lib64/libpthread-2.5.so)
> ==18555==    by 0x331BABB5: opal_thread_start (in
> ==18555==    by 0x32F43A18: orte_ess_base_app_setup (in
> ==18555==    by 0x34C503DE: rte_init (in
> /home/hector/installed/openmpi-intel/lib/openmpi/mca_ess_singleton.so)
> ==18555==    by 0x32F222F5: orte_init (in
> ==18555==    by 0x32A4D67E: ompi_mpi_init (in
> ==18555==    by 0x32A7052E: PMPI_Init (in
> ==18555==    by 0x3122CB27: PMPI_INIT (in
> /home/hector/installed/openmpi-intel/lib/libmpi_mpifh.so.2.5.0)
> ==18555==    by 0x1C89281: setprcs_ (man.f:144)
> ==18555==    by 0x1C4CB98: MAIN__ (main.f:114)
> ==18555==
> ==18555== 7,550 bytes in 111 blocks are definitely lost in loss record
> 6,243 of 6,383
> ==18555==    at 0x2ECC0A3D: realloc (vg_replace_malloc.c:692)
> ==18555==    by 0x324D469725: vasprintf (in /lib64/libc-2.5.so)
> ==18555==    by 0x324D44D727: asprintf (in /lib64/libc-2.5.so)
> ==18555==    by 0x331E913D: dlopen_foreachfile (in
> ==18555==    by 0x331CCBC0: mca_base_component_find (in
> ==18555==    by 0x331D5EC0: mca_base_framework_components_register (in
> ==18555==    by 0x331D62DE: mca_base_framework_register (in
> ==18555==    by 0x331D6331: mca_base_framework_open (in
> ==18555==    by 0x331B71E8: opal_init (in
> ==18555==    by 0x32F221C4: orte_init (in
> ==18555==
> ==18555== LEAK SUMMARY:
> ==18555==    definitely lost: 7,790 bytes in 117 blocks
> ==18555==    indirectly lost: 0 bytes in 0 blocks
> ==18555==      possibly lost: 336 bytes in 1 blocks
> ==18555==    still reachable: 52,608,059 bytes in 7,817 blocks
> ==18555==         suppressed: 0 bytes in 0 blocks
> ==18555== Reachable blocks (those to which a pointer was found) are not shown.
> ==18555== To see them, rerun with: --leak-check=full --show-leak-kinds=all
> ==18555==
> ==18555== For counts of detected and suppressed errors, rerun with: -v
> ==18555== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 4 from 4)
> Hector
> On Fri, Jun 19, 2015 at 2:29 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> PETSc thinks there is an error in user code. Its best if you run it in
>> a debugger and check whats going on. [on linux one can also use
>> valgrind to track down problems]
>> There are many changes from petsc3.1 to petsc-3.6. Make sure
>> you go throgh the changes files. On C - one can rely on the compiler
>> prototype checks to catch most of the changes. But with fortran - you
>> might have to rely on a debugger/valgrind to [and the changes docs]
>> to find the changes.
>> http://www.mcs.anl.gov/petsc/documentation/changes/index.html
>> Satish
>> On Fri, 19 Jun 2015, Hector E Barrios Molano wrote:
>>> Hi Satish,
>>> I used MatSetOption, I'm ignoring the performance penalty for now.
>>> Now I have this error:
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: See
>>> shooting.
>>> [0]PETSC ERROR: F:\prog_win\prog\Debug\prog.exe on a windows-intel
>>> named HECTOR-PC by hector Fri Jun 19 14:06:17 2015
>>> [0]PETSC ERROR: Configure options --with-cc="win32fe cl"
>>> --with-fc="win32fe ifort" --prefix=/cygdrive/c/Installed/petsc/
>>> --PETSC_ARCH=windows-intel
>>> --with-parmetis-include=/cygdrive/c/Installed/parmetis/include
>>> --with-parmetis-lib=/cygdrive/c/Installed/parmetis/lib/parmetis.lib
>>> --with-metis-include=/cygdrive/c/Installed/parmetis/include
>>> --with-metis-lib=/cygdrive/c/Installed/parmetis/lib/metis.lib
>>> --with-mpi-include="[/cygdrive/c/Installed/msmpi/Include,/cygdrive/c/Installed/msmpi/Include/x64]"
>>> --with-mpi-lib="[/cygdrive/c/Installed/msmpi/Lib/x64/msmpi.lib,/cygdrive/c/Installed/msmpi/Lib/x64/msmpifec.lib]"
>>> --with-blas-lapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_intel_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_sequential.lib]"
>>> --with-scalapack-include=/cygdrive/c/Installed/mkl/include
>>> --with-scalapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_scalapack_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_blacs_msmpi_lp64.lib]"
>>> job aborted:
>>> [ranks] message
>>> [0] application aborted
>>> aborting MPI_COMM_WORLD (comm=0x44000000), error 59, comm rank 0
>>> On Fri, Jun 19, 2015 at 12:57 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> As the message says:
>>>>> [0]PETSC ERROR: New nonzero at (0,20) caused a malloc
>>>>> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check
>>>> Note: mallocs make the code slow - so its up to you to do a proper
>>>> preallocation of memory - or disable the check as the above message
>>>> indicadtes [and ignore the performance penalty for now.].
>>>> Satish
>>>>> Hi PETSc Experts,
>>>>> I'm compiling a Windows program using petsc-dev, this program
>>>>> previously used petsc-3.1 the only change performed was:
>>>>> MatCreateMPIBAIJ --> MatCreateBAIJ
>>>>> As the PETSc documentation suggested.
>>>>> I only changed the name of the function.
>>>>> I got to a problem when the program is launched and PETSc is called by
>>>>> the program:
>>>>> [0]PETSC ERROR: Argument out of range
>>>>> turn off this check
>>>>> [0]PETSC ERROR: See
>>>>> shooting.
>>>>> named HECTOR-PC by hector Thu Jun 18 18:31:42 2015
>>>>> [0]PETSC ERROR: #1 MatSetValues_SeqBAIJ() line 2192 in
>>>>> C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c
>>>>> [0]PETSC ERROR: #2 MatSetValues() line 1175 in
>>>>> C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c
>>>>> [0]PETSC ERROR: New nonzero at (1,21) caused a malloc
>>>>> turn off this check
>>>>> [0]PETSC ERROR: See
>>>>> shooting.
>>>>> [0]PETSC ERROR: #3 MatSetValues_SeqBAIJ() line 2192 in
>>>>> [0]PETSC ERROR: #4 MatSetValues() line 1175 in
>>>>> [0]PETSC ERROR: #3599 MatSetValues_SeqBAIJ() line 2192 in
>>>>> [0]PETSC ERROR: #3600 MatSetValues() line 1175 in
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: [0] MatSetValues line 1142
>>>>> [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148
>>>>> [0]PETSC ERROR: See
>>>>> shooting.
>>>>> named HECTOR-PC by hector Fri Jun 19 12:43:06 2015
>>>>> [0]PETSC ERROR: #3601 User provided function() line 0 in  unknown file
>>>>> job aborted:
>>>>> [ranks] message
>>>>> I'm compiling the program on Visual Studio, what could be the problem?
>>>>> Thanks for your help,
>>>>> Hector
