[petsc-dev] config fail on OSX with master
Fri Jun 19 14:24:58 CDT 2015
  Satish,
   Hmm, this could be a bug in sowing, could you run a full build of PETSc fortranstubs using bfort but run bfort under valgrind?
   Thanks
   Barry
We had another report of the same type with a mysterious misunderstanding of a filename.
> On Jun 19, 2015, at 10:42 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> include config file /Users/markadams/Codes/petsc_fresh/lib/petsc/conf/bfort-petsc.txt^DP`¨^? missing
> Unable to read configure file bfort-base.txt*******
> Do you have this file? I don't know where the funny chars at the end of the filename are coming from..
> Satish
> On Fri, 19 Jun 2015, Mark Adams wrote:
